So much white smoke!!!
- Coder88
Today I was in the process of replacing a head gasket and my thermostat. I got the thermostat in and started removing the head. I started to take off all the bolts to remove the head and then Realized I was running out of light so I cranked everything back down and packed everything up. I started the bike and after warming for a few minutes it started pouring white smoke when it idled but at higher revs the smoke went away. Could I have damaged the head gasket even more by removing those bolts?
1980 GL1100 - KnightWing
Re: So much white smoke!!!
My question would be, why did you start the bike at all if you knew there was a issue?Coder88 wrote:Today I was in the process of replacing a head gasket and my thermostat. I got the thermostat in and started removing the head. I started to take off all the bolts to remove the head and then Realized I was running out of light so I cranked everything back down and packed everything up. I started the bike and after warming for a few minutes it started pouring white smoke when it idled but at higher revs the smoke went away. Could I have damaged the head gasket even more by removing those bolts?
78 GL1000 Original Owner 131k
- Coder88
Coder88 wrote:Anyone have any ideas?
Did it smoke that bad before? I'm not sure why you would have started the bike either after starting to remove the head. But yes, you very well may have disturbed the gasket enough to make it leak that bad. Did the smoke ever go away completely?
- 77Pinto
Mine too, but I would go farther by asking if you pull out the head bolts and then put them back in why would you think you wouldn't have more problems.....SnoBrdr wrote:
Bill
1976 GL1000 LTD (X2)
1976 GL1000 Sulfur
1977 GL1000
1976 GL1000 Sulfur
1977 GL1000
Nothing I can add. Everyone seems to have covered it pretty good. When you re0- installed the head bolts, did you torque them or just tighten them down? Really doesn't matter I guess. Just change the gasket and move on
- 6 Replies
- 566 Views
Last post by robin1731
- 18 Replies
- 1194 Views
Last post by roncar
- 17 Replies
- 1172 Views
Last post by Lucien Harpress
- 57 Replies
- 3157 Views
Last post by Beetleman
- 11 Replies
- 1630 Views
Last post by Gowing
