So I was disassembling my carbs to do the Randakk rebuild. Took all the vacuum chambers off and found that the #4 carb vacuum piston does not move freely in the vacuum chamber. 1 2 and 3 move freely from top to bottom of chamber. 4 piston moves freely only about 3/4" and then sticks as it goes higher in the chamber. It gets progressively more stuck the higher in the chamber it goes.
Do I need a whole new #4 carb or just the chamber and piston? Is this correctable without having to swap any parts? I lubed the rim of the piston and inner wall of chamber but that changed nothing.
How far does the piston actually move within the chamber while running? Does it need the full length of the chamber?
81 GL1100 Carburetor trouble...
- Cadillac Kid
1981 GL1100
- terry_208
Re: 81 GL1100 Carburetor trouble...
I believe they're run dry. I there corrosion in the chamber? Try polishing both the piston and chamber with aluminum foil. Someone with more experience will be along shortly.
Terry
1976 GL1000
1976 GL1000
- mikenixon
- Early 'Wing Guru
Usually it's a ding in the vacuum top. Any rough treatment on the outside of the cap (top) results in distortion of the top's interior. Prove this by swapping that slide to a different top and that top to a different slide. The top can't be corrected. Sanding destroys the necessary close tolerance. The good news us there are boatloads of used tops available.
Mike Nixon
www.motorcycleproject.com
https://youtu.be/CDnzwDWhN24
- Cadillac Kid
http://pages.ebay.com/motors/link/?nav= ... 89&alt=web
someone is selling the #1 chamber and piston on ebay. Mine is the #4. Can I use it?
1981 GL1100
- RIP: cookie
Yep .....
- Cadillac Kid
Ok. Got a replacement chamber and piston. It is the old piston that is defective.... only problem is the new piston has a bad needle. Can they be swapped/removed? The needle on my old piston is fine.
1981 GL1100
- RB
Yep should be the same.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- Cadillac Kid
- 19 Replies
- 2390 Views
Last post by redglbx
- 4 Replies
- 581 Views
Last post by Whiskerfish
- 17 Replies
- 537 Views
Last post by Sagebrush
- 6 Replies
- 498 Views
Last post by robin1731
