Should I Replace The Stator Or Convert To GM Alternator?
Re: Should I Replace The Stator Or Convert To GM Alternator?
#46
salukispeed wrote:I also have the very small Denso rated at 40 Amps I would like to try on my 84 Interstate. I am a bit concerned if I butcher the metal heat shield that deflects the radiator heated air around the carbs I could then run into the Vapor lock and fuel issues some have. I installed a new Honda stock stator a couple years ago and it works very well but I have been thinking about more cold weather riding and a few electric heated accessories could really make a difference there. It is about 50 miles each way to work. I even considered a pair of 12 volt batteries to run the accessories but then recharging them would be inconvenient.
I guess the truth is that I want everything for very little effort or cost and that does not seem to be working well.
Not sure about the vapor lock being an issue. The 1200 does use an electric fuel pump.
#47
I remove the heat shield on all my bikes, and have never had a carb issue. Warm weather, hot weather, or cold weather. A little more heat in the summer, as stated. But a little warm air in the winter.
Dirt Road Cowboy
#48
Post by Dirt Road Cowboy »
I rode a 72 Ironhead Sportster and an old late 60's BSA with an air-cooled iron engine.
Somehow I don't think the Wing will be much worse! lolol
I'm going to be pulling all the Vetter stuff off soon, to be able to work on everything, and I'll probably be keeping it off for a little while so that I can get used to riding a big bike again. I sure do miss riding!
Here is a pic of her on a little road trip just after I bought her. This is her best side since she was missing the battery cover.
my 78 wing
my 78 wing
78 GL1000
DirtRoadCowboy.com
Dirt Road Cowboy
#49
So, should I document the work on this thread, or under Customizations, or Restorations?
It won't be a stock resto with the alternator and single carb, but it isn't going to be a custom bobber, cafe or chopper either.
type1
78 GL1000
DirtRoadCowboy.com
#50
you might start a thread to specifically document it. Just my humble opinion (Okay I am not humble, but I am opinionated) The tech forum will be seen by more peole during the actual thread, vs the resto or cuztom
