Should I Replace The Stator Or Convert To GM Alternator?
Re: Should I Replace The Stator Or Convert To GM Alternator?
Most Alternators, including the ones I use, are a one wire system. A single wire from the post on the alt. to the positive battery post. Regulator is internal, and the ground is provided by the body of the Alternator.. No other wires needed. The only other wire is to turn on a dash light if it fails to charge
- 82aspy
pix maybe?
desertrefugee wrote:I picked field coil excitation voltage for my GM alternator from an accessory lug in the fuse box. The eight gauge charging wire runs straight off the positive terminal of the battery through a resettable 50 amp breaker.
I removed my factory regulator/rectifier unit and forgot about the stator.
Forever.
Pics. (This is on my '84 Aspencade)
I documented the installation on another site a few years back. I took lots of pictures. A couple focused on the wiring are below. I used the small 55A Geo Metro alternator recommended by Don (Poorboy). It's nice and small and works like a charm.
The blue wire feeds the "excitation" terminal on the alternator. It's switched with the key. A good thing. The charge line runs under the battery cover and includes a 50A manual reset breaker on the old connector tab left of the battery. (And yes, it's well insulated. That's a lot of high current +12V surface area near easy access to chassis ground).
- Blue wire "excitation" voltage.
- 2012-02-15_21-58-16_17.jpg (99.78 KiB) Viewed 557 times
- Charge line
- 2012-02-18_16-19-10_270.jpg (95.71 KiB) Viewed 557 times
- 82aspy
tx, should have been more clear, the gm alt setup?
This install has been documented countless times on various Goldwing sites. Mine was very routine.
One mounting "ear" must be removed. Plus, I had to "clearance" the remaining top ear to get the pulley to align perfectly. It might've been OK as it was, but I didn't want premature belt wear or the possibility of tossing the belt on the wrong side of the tracks.
- "Thinned" the ear down to better align the pulleys.
- 2012-02-19_13-32-29_757.jpg (54.23 KiB) Viewed 553 times
- Scrapped off a little aluminum to clear the choke linkage.
- 2012-02-18_15-46-18_653.jpg (76.25 KiB) Viewed 553 times
- Brackets from the Poorboy kit made short work of the install. (An industrious fellow could make his own).
- 2012-02-18_16-08-50_101.jpg (80.2 KiB) Viewed 553 times
- Fan shroud and bracket need "alterations".
- 2012-02-18_12-12-17_658.jpg (71.35 KiB) Viewed 553 times
- Bottom of the radiator kicks out (with spacers) about an inch to clear the pulley.
- 2012-02-19_09-18-21_997.jpg (50.43 KiB) Viewed 553 times
Gotta hog out the timing covers to clear the pulley. This one is not nearly done. Goes pretty much all the way to the circle seen in the casting.
- 2012-02-15_21-58-04_260.jpg (85.42 KiB) Viewed 553 times
- Hookup is a pretty straightforward affair.
- IMG_2360.JPG (70.54 KiB) Viewed 553 times
I too, like several others, wonder why two stators failed. Both my 1000's still have their original stators and the 1200 crapped out after 28 years.
- Dirt Road Cowboy
I wish I knew why they went out. All I know is that they did.rcmatt007 wrote:I too, like several others, wonder why two stators failed. Both my 1000's still have their original stators and the 1200 crapped out after 28 years.
This was my first Wing, and by what everyone said about them, I really expected more from it. When it went out 3 years ago, I had to just park the bike, and haven't been able to do anything with it until now.
I don't know where the PO had the work done, or where they got the replacement stator (he showed me the receipt, but I don't remember the details). He paid $1,200 to have it done, and for all I know, they may have put a used stator in. All I can say is that the one I bought was an OEM Honda NOS. Maybe it was old and going bad? Can they go bad from sitting on a shelf in their original packaging?
I was really hoping that there was some other problem, but when I tested the output on the 3 wires I got something like: 50v, 50v, 7v, and the output to the battery was 10.2v.
The new stator came in yesterday. I haven't tested it yet, but I really think I should go with the alternator on the 78 Wing, and save the stator for the 75. I like the idea of being able to access the alternator easily on road trips, and apparently Honda finally decided that an external alternator was a better idea too, since all the newer Wings have external alternators instead of hidden stators.
I had thought about going with a Poor Boy kit, but they don't fit the 1000, and back then, I didn't have any tools to make my own setup. I did have a retired machinist make a pulley for me with the 10mm bolt hole, and a heavy duty shaft, but until I found the $40 GM Alternator Conversion post on this site, I really didn't know what to do with the brackets.
Now that I have a few more tools, a plan, and some time, I think that I should be able to pull the conversion off!
Thanks for the advice everyone.
78 GL1000
DirtRoadCowboy.com
DirtRoadCowboy.com
they should not go bad sitting on the shelf, paying someone to replace a stator is $$$ because you have to pull the engine. If I recall, one risk is demagnizing (sp?) the outside part... dropping it for example
- 82aspy
http://www.donaldantiquerototillers.com/Alternator.htmlDirt Road Cowboy wrote:I had thought about going with a Poor Boy kit, but they don't fit the 1000, and back then, I didn't have any tools to make my own setup. I did have a retired machinist make a pulley for me with the 10mm bolt hole, and a heavy duty shaft, but until I found the $40 GM Alternator Conversion post on this site, I really didn't know what to do with the brackets.
- Dirt Road Cowboy
I thought about doing something like that, until I found this one here on NGW:82aspy wrote: http://www.donaldantiquerototillers.com/Alternator.html
http://ngwclub.com/forum/viewtopic.php?t=41463
This one is really cool because everything is hidden under the false tank. I already started making the cardboard templates for it using the open 75 frame as a guide, along with the GM alternator out of my wife's 1980 El Camino.
Once I get the mock up looking the way I want it, I'll transfer the pattern to steel, and cut the pieces. I need to remember to take photos of the process for the next guy that needs it for a GL1000.
78 GL1000
DirtRoadCowboy.com
DirtRoadCowboy.com
- 82aspy
Dirt Road Cowboy wrote: I need to remember to take photos of the process for the next guy that needs it for a GL1000.
- 82aspy
there many other examples out therercmatt007 wrote:I too, like several others, wonder why two stators failed..
sure, but other than the bad batch in the first 1200's nearly all of these bikes have and still have stators that are decades old. If someone told me that had several alternators go out in a row on their car, I would wonder the same thing. Not any different than if I see a patient for the same thing more than a couple of times, I have to think different about what I am doing, cuase what I am doing just aint working82aspy wrote:there many other examples out therercmatt007 wrote:I too, like several others, wonder why two stators failed..
Now I have heard that maybe some electronic stuff imported cheaply is exactly that.... cheap....
- 82aspy
too many stator stories out there for me to go there, unless perhaps engine out for other reasons
- 59 Replies
- 2234 Views
Last post by rcmatt007
- 20 Replies
- 1084 Views
Last post by JSBail
- 14 Replies
- 537 Views
Last post by salukispeed
- 14 Replies
- 1440 Views
Last post by bigtex
- 4 Replies
- 583 Views
Last post by Gank
