Shortening the Carb air intake.
- NCScooter
- My Album: http://ngwclub.com/gallery3/index.php/w ... ter?page=1
Re: Shortening the Carb air intake.
I apologize for the abject stupidity of my previous post. I should know by now that "everything effects everything." I actually have an airbox off an 1100 on my GL1000. PO had 1100 carbs on it. I have the correct carbs now. I'm wondering if someone could tell me the I.D. of the snorkel on the 1000 airbox so I could compare it to the cross section of snorkels on the airbox I have. Mrs. Brown was right. Geography or geology or geometry or whatever she was teachin' is used by adults.
I need to remember to keep my expectations tiny so I don't end up so whiny.
1976 CB400f
1977 GL1000-The Breeze
I'm so special, my short bus only has two wheels!
1976 CB400f
rcmatt007 wrote:what I cut was the metal air filter holder, and then welded the flat plat and the round piece on it
There was no welding on mine. Just cut the stock base to fit the filter I had. You can see it well enough I think in the pic.
- SANY0204.jpg (239.47 KiB) Viewed 310 times
- randakk
- Early 'Wing Guru
Bingo! That why no one messes with the OEM air filter setup on any Honda of this vintage ...unless you like a good science project.mrtwowheel wrote:Just thinking that any change to the intake on CV carbs can cause a drastic change in the vacuum that these types of carbs need to work properly. Just changing the size of the filter area would change vacuum flow. I'm just leery of changing anything about the fuel and air, even the one carb setups.
Scott
These bikes will tolerate just about any exhaust without the need to mess with the jetting. But, they are VERY sensitive to any change on the intake side.
Randall Washington (Randakk)
Retired Founder - www.randakks.com/
Curator - www.facebook.com/groups/CarburetorAppreciationSociety
- 17 Replies
- 925 Views
Last post by Sidecar Bob
- 8 Replies
- 2627 Views
Last post by 82aspy
- 3 Replies
- 474 Views
Last post by leggman
- 4 Replies
- 487 Views
Last post by CYBORG
