Dyna S Ignition
- Hanslehoff
Dyna S Ignition
I'm in the process of doing a cafe build and part of it involves swapping in a different motor. My build thread is here: http://www.ngwclub.com/forum/viewtopic.php?f=16&t=56574
I pulled the points cover off this afternoon and discovered that my new motor has a Dyna S ignition in it. I had planned on upgrading to an electronic ignition some time in the future, so this was a pleasant surprise. But...I don't know anything about them! The rest of my bike has all the stock wiring. Will I need anything else for this to work or is it simple plug and play?
Here's what it looks like:
1975 Cafe Wing
Re: Dyna S Ignition
If you go to 'ShopTalk' you will find three threads concerning installation and adjustment of the Dyna ignition... http://ngwclub.com/forum/viewtopic.php?t=5614 http://ngwclub.com/forum/viewtopic.php?t=5720 http://www.ngwclub.com/forum/viewtopic.php?f=1&t=23790 That should give you a good start...
Good wrenchin'
Todd
Good wrenchin'
Todd
Re: Dyna S Ignition
+1 you can also download instructions from http://www.dynaonline.com/skins/downloads/Default.aspx
- Hanslehoff
Re: Dyna S Ignition
I read through the instructions and I think I understand. I bought the motor separate, so I only have the ignition with the three wires coming out from the points cover. I don't have the Dyna resistor to replace the stock one with or the wiring to patch into the 12v lead. Is there any way to order just those missing items? Or if I'm understanding correctly, I can buy the high performance Dyna ignition coils?
1975 Cafe Wing
Re: Dyna S Ignition
You can use it with any 3ohm coils, gl1200, or Gl1500's. The 1500's are pretty cheap on eBay. Buy a set and you have one backup coil. IMHO, this is a good swap as you can also replace wires. However, your bike is pretty original looking, so you might want to keep it stock. I would think Dyna would still have the ballasts or steer you to the right one.
- Hanslehoff
Re: Dyna S Ignition
My bike is in the midst of a complete rebuild / modification so keeping things stock is no longer an issue. I will attempt to get in contact with Dyna and see what they recommend.
1975 Cafe Wing
- gregforesi
Re: Dyna S Ignition
On early installations of Dynas, they recommended pulling the power from the turn indicator circuit. Occasionally this has resulted in the bike going dead just because something happened to the turn indicators. If you pull the power for the red Dyna lead from some other switched circuit you can eliminate that possible issue.
Dyna's tech support is pretty good. They will hook you up with the ballast resistor to use with your stock coils. While the Dyna ignition simply eliminates the maintenance of points, moving up to the Dyna coils (or other more modern coils I suppose) is a decent performance upgrade over stock.
2006 GL1800 (Brutus Maximus)
Re: Dyna S Ignition
Hanslehoff wrote:My bike is in the midst of a complete rebuild / modification so keeping things stock is no longer an issue. I will attempt to get in contact with Dyna and see what they recommend.
I would just put new Dyna 3ohm coils on it. Don't need the resistor then.
- Toehead
Re: Dyna S Ignition
GL1500 coils are also 3.0 ohms. I run mine without the resistor, and it is a really good combination.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- Hanslehoff
Re: Dyna S Ignition
I ordered a set of the 3ohm coils from dyna and will splice in a power supply when I wore it al, up. Thanks guys!
1975 Cafe Wing
- 0 Replies
- 427 Views
Last post by gltriker
- 10 Replies
- 561 Views
Last post by ericheath
- 15 Replies
- 892 Views
Last post by oldmike
- 4 Replies
- 502 Views
Last post by overboostin
