Easiest wire to tie in a Voltmeter?
- BlueThunder
Re: Easiest wire to tie in a Voltmeter?
I think this is being over analysed. Wire it to the Brown/White (gauge lights) or the Black/Red in the left faux tank cover. Both circuits are switched. If you are worried about voltage drop due to dirty, old connections, perhaps its a sign to clean and/or replace them. The tolerance of the voltmeter most likely exceeds any voltage drop.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Pretty much my exact message about three posts back...
- BlueThunder
Hmm... needed my two cents.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
I just installed a relay in the voltage sense wire to the regulator. This was to correct an overcharging issue due to voltage loss thru the ignition switch. I plan to add an idiot light off of the sense wire to monitor the charging voltage. As soon as I find the perfect spot to put it. This is a switched 12V. It is almost a direct connect to the battery. Just goes thru a relay.
__________________________________
84 Goldwing Standard
48 Harley Panhead Custom
- Tin Member
Just installed a digital voltmeter using the blinker relay wires :
https://www.youtube.com/watch?v=fOlPd7KoBG8
https://www.youtube.com/watch?v=jv_EnfeQR1g
1976 GL 1000 Jaune sulfure.
- andorragl
Thomas44 wrote:Just installed a digital voltmeter using the blinker relay wires :
The easiest and cleanest way to install a voltmeter on a gl1000 that I had never seen. Both the wiring and the place where you installed it. In my opinion, just great.
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
- 8 Replies
- 253 Views
Last post by Brant
- 13 Replies
- 274 Views
Last post by Dirty Dave
- 12 Replies
- 634 Views
Last post by heraldhamster
