gl1000: front brakes: banjo crush washers
Hi All- are the "sides" of the crusher fussy about which way they face? one side seems smooth the other side rougher and one edge rounded the other edge square cut..thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
Re: gl1000: front brakes: banjo crush washers
They started out smooth on both sides. Over time the take the shape of the banjo. Many time's I've "sanded" them a little to make them some what flat again. Just a clean up really.
Crush washers, like most any flat stock item, are manufactured by stamping, which typically rounds the top edge, and sharpens the bottom edge. It should not affect the seal, although if used multiple times, crush washers can lose their 'elasticity.' Personally, when I'm being kind of obsessive, I make sure to place the 'sharp' edge down. But that's me...
+1 on the obsessiveness! I always put flat washers with the flat side down! I figure that's why the call them "flat" washers!
John
John
1977 GL1000/1976 GL1000
1975 GL1000/1975 GL1000 (Parts Bike)
2002 FLHRCI/1993 ZR750C3 Zephyr
1982 GS750EZ/1978 GS550
1978 KZ1000A2/1978 KZ1000A2 (frame only)
1980 KZ650F1/1979 KZ650B3
1979 KZ650C3/1981 KZ550A1
1977 KZ400A1 Deluxe/1979 KZ400B2
1982 KZ250D2/1980 KZ750E w/parts bike
This is not MY circus and You are not my monkeys!
- gregforesi
I'm with the Trackman on this. Whether they are copper or aluminum (oil drain plug) it's the softness that makes them work. Shouldn't matter which side goes where but once they've been used, replacement is something to think about.
2006 GL1800 (Brutus Maximus)
just take a look how most of our oil drain bolt crush washer mushrooms over time. They are pretty cheap, doesn't hurt to replace them occasionally (IMHO)
- 148 Views
Last post by zipster
- 3 Replies
- 246 Views
Last post by gltriker
- 9 Replies
- 354 Views
Last post by BlueThunder
- 4 Replies
- 262 Views
Last post by bulldozer
