sounds like a really good deal to me. The new brushes are $30 alone. Not sure on the bushing but I don't think I'd rebuild one for $60. Although once out of the bike and on the bench it doesn't take long at all.. Maybe like 20 or 30 minutes to clean everything and put it back together.Don R wrote:My 79 with 33K had a bad bearing in it, it was the one nearest to the planet gears. My local rebuilder put a new one in and did the brushes. $60.
Starter motor drags
- jdvorchak
Re: Starter motor drags
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- salukispeed
Don't make the mistake of trying sub standard brushes without knowing the requirements. There are different blends of copper, graphite and carbon and each has its merit. For kicks and because I am cheap at times I tried hardware store carbon brushes in a lawn tractor starter and it worked great for two cuttings before it damaged the commutator beyond repair and I needed a new one instead of spending the $22 a set from the manufacture.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Didnt rebuild it yet, but I did take it apart and clean it well. Had lots of carbon dust inside and I cleaned the armature. Put a smear of grease in the bushings as well. Rode it and got it good and hot and shut it off and tried to restart it. The dragging didnt happen this time like it was doing before..hope it holds off till next spring.
My bikes::
1972 Honda CB 350
1973 Yamaha TX 750
1975 Honda GL1000 Goldwing
1976 Kawasaki KZ 650B1
1977 Suzuki GS 750B
1978 Suzuki GS 1000C ( 2 )
1978 Suzuki GS 1000E
1979 Suzuki GS 1000S..Real Deal right from Japan
1983 Honda CB650 Nighthawk
1983 Suzuki GS 650G
1972 Honda CB 350
1973 Yamaha TX 750
1977 Suzuki GS 750B
1983 Suzuki GS 650G
That sounds like a positive fix to me... I imagine the battery is fully charged after a ride and you have also disturbed most battery and electrical connections related to starter... With the battery fully charged and all terminals cleaned it is an absolute joy to hit the button for an instant start...CHUCK HAHN wrote:Didnt rebuild it yet, but I did take it apart and clean it well. Had lots of carbon dust inside and I cleaned the armature. Put a smear of grease in the bushings as well. Rode it and got it good and hot and shut it off and tried to restart it. The dragging didnt happen this time like it was doing before..hope it holds off till next spring.
IMO, Give it 7-10 day when the lead acid battery has "gone off" peak power (even new) you will likely hear the "drag" once again... If you can keep a "solar/trickle charger" fitted to a lead acid battery most starting problems will be resolved..
Humidity and cold temp also affect starting ease... They have for me in the past!!!
1975 Goldwing #1 SOLD
Battery is new this spring, the terminals were cleaned, the charging at the battery shows a good 14.1, the starter had a lot of carbon dust in uit when i opened it, and the armature was dirty..that bronze colored glaze on it. After riding it BEFORE I cleaned it , the starter always seemed to drag a bit before catching a good crank. That seems to be gone now. It always cranked great when cold engine and acted up aferwards. Thats what prompted me to take a gander at it.
My bikes::
1972 Honda CB 350
1973 Yamaha TX 750
1977 Suzuki GS 750B
1983 Suzuki GS 650G
1972 Honda CB 350
1973 Yamaha TX 750
1977 Suzuki GS 750B
1983 Suzuki GS 650G
- 3 Replies
- 552 Views
Last post by Old Fogey
- 6 Replies
- 580 Views
Last post by Giuliano
- 6 Replies
- 367 Views
Last post by Barney T Weasel
- 6 Replies
- 440 Views
Last post by Sidecar Bob
- 10 Replies
- 684 Views
Last post by pidjones
