1980 GL1100 air shock rebuild. New springs. Need guidance
I am rebuilding a set of air shocks off of a 1980 GL1100 for a project I'm working on. The new springs and seal kits came from Progressive. I also ordered two new internal bumpers. I have read all I can find on the process and watched several videos with interest.
So far so good until I started to reassemble the components.
The new inner spring does not fit into the sleeve like the old spring (see photo).
The outer spring in fine.
Thoughts, suggestions. Thanks.
- image.jpeg (103.37 KiB) Viewed 484 times
- image.jpeg (101.29 KiB) Viewed 484 times
- image.jpeg (84.27 KiB) Viewed 484 times
It's all good.
Re: 1980 GL1100 air shock rebuild. New Progressive springs/s
Parts list
- image.jpeg (76.67 KiB) Viewed 483 times
- image.jpeg (31.24 KiB) Viewed 483 times
- image.jpeg (90.49 KiB) Viewed 483 times
- image.jpeg (44.64 KiB) Viewed 483 times
It's all good.
Re: 1980 GL1100 air shock rebuild. New springs. Need guidanc
I've not done this fix (yet) so my opinion is based on only what I can see in your pictures. It looks as though the issue is only a tight fit in the sleeve, is that correct? When assembled, I can't see that there would be any chance of (or reason for) movement of the inner spring within the sleeve. IMhO, enlarge the inner diameter of the sleeve using sandpaper or the like just enough to allow free movement of the new spring. Try to keep it even, and get it as smooth as possible.
I wouldn't doubt that Progressive has a tech support line or email contact, and this would probably be a common issue. You might check that out first... My 2 cents...
Thanks for your suggestions. After repeated calls/messages, and email to Progressive with no response, I moved on to enlarging to ID of the sleeve. A combination of removing material, leaving the springs overnight in the freezer and setting the sleeves in the warm CA sun resulted in the springs slipping right in. They weren't going to mate without the hot/cold. I won't call it an interference fit, but it's TIGHT.
Thanks again.
Thanks again.
- image.jpeg (128.94 KiB) Viewed 457 times
- image.jpeg (73.16 KiB) Viewed 457 times
- image.jpeg (107.78 KiB) Viewed 457 times
It's all good.
- 82aspy
oil seals fit ok? I think they are supposed to be 1100 -1200 suitable? and even Progressive Suspension 416 series air shocks
82aspy wrote:oil seals fit ok? I think they are supposed to be 1100 -1200 suitable? and even Progressive Suspension 416 series air shocks
Yes. They measured out fine. As soon as I polish the top lug mounts I'll reassemble them.
It's all good.
Today was polish day. I have three bike projects going on at one time so polish, polish, polish. Top of the list was the top of the GL1000 air shocks. Everything will go back together on Monday.
The second photo is before and after cleaning/wire brushing.
- image.jpeg (32.18 KiB) Viewed 422 times
- image.jpeg (31.8 KiB) Viewed 422 times
It's all good.
- 82aspy
The shocks are complete. 10oz of ATF and 20lbs pressure with a two day leak down test shows all is good.
- image.jpeg (102.01 KiB) Viewed 393 times
It's all good.
I used the fork lowers to "set" the shock seals.
- image.jpeg (56.96 KiB) Viewed 386 times
It's all good.
- 82aspy
you have the steel sleeves/bushings inserts that go in the end rubbers?
Yes sir. Bagged and tagged for final assembly on the bike.
It's all good.
- jdvorchak
Really nice job and looks like great results! Congrats!
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- jdvorchak
Just curious are those new gators or the original? If new where did you get them and how much? If you don't mind me asking.
2021 HD Triglide
John
2021 HD Triglide
John
- 11 Replies
- 261 Views
Last post by Whiskerfish
- 214 Views
Last post by milesoffun
- 15 Replies
- 892 Views
Last post by toomanybikes
- 3 Replies
- 130 Views
Last post by Whosdatguy
