Throttle cable help. How do you fit them?
I have looked all over the place but can't find any help on how to fit the two cable system! Does anyone have a tutorial or any advice on how to fit them?
Thanks in advance
Thanks in advance
1975 Honda GL1000
1978 Montesa Cota 348
1966 MG Midget
1966 MG Midget
Re: Throttle cable help. How do you fit them?
Not real sure what you specifically need to know or mean.
Remove the false tank and route them down the left frame rail to the carbs.
As an alternative method, you can remove cables at either end tape the new ones end to end and pull them through, connect and adjust.
Just know it will make it very difficult to connect and adjust cables with false tank in place.
Make sure throttle snaps back closed after installation and adjustment with bars turned full right and full left.
You should add the year of your bike and model if different in your signature. It will get you faster answers.
Try here for a drawing for75-79: http://forum.classicgoldwings.com/galle ... e_id=11158
Thank you chrisz that's exactly what I needed, I did not know which cable was which or where either end went!
Must pay attention toon when taking things apart!!!
1975 Honda GL1000
1966 MG Midget
1966 MG Midget
Jimmy, You were right to ask. Like me, if I had simply routed the replacement throttle cables a PO had done, they would not have worked as smoothly.
Present bikes -
BMW R100/7
1989 BMW R100GS-Paris Dakar
MZ ETZ250 Trials
1977 Honda GL1000 GoldWing
BMW R100/7
MZ ETZ250 Trials
- Tin Member
I'm about to do my throttle cables on a 82 Goldwing interstate. What I've read so far it looks like a big job.
couple hours probably. Takes a bit of patience. Proper Routing is pretty critical so make sure to snap a bunch of pics or somehow document how it is when you start.
- Tin Member
Yes I read that in another article. Make sure you route the cables right
Hemostats (medium and large - Harbor Freight has them). Are a great aid in installing such cables.
- 347 Views
Last post by Olyclo
- 7 Replies
- 256 Views
Last post by GLDCW
- 25 Replies
- 2294 Views
Last post by Sidecar Bob
- 1 Replies
- 145 Views
Last post by wingrider
