Carb sync
- Zinc Member
Carb sync
Hi all
I did my carb sync recently.
Two things came to mind.
1. It was very very hard to lock the locknuts up without adjusting the balance.
2. I set the idle to 1000rpm, went for a long ride today and after a fast bit in the road my idle rpm shot up to 2000rpm and stayed there.
I got back and hooked up the vaccum gauges again, suspecting that a locknut was not done tight enough, but they where all still balanced. I set the idle back to 1000rpm and all was well.
Not sure what happened there, maybe the idle set screw moved?
1979 Gl1000 KZ
Re: Carb sync
Maybe...but I would look for a vacuum leak. re-tighten the manafold clamps. Good place to start
- Zinc Member
Re: Carb sync
I will double check. I did check with brake cleaner etc around the areas recently and no rev increase. All the screws are tight etc.CYBORG wrote:Maybe...but I would look for a vacuum leak. re-tighten the manafold clamps. Good place to start
1979 Gl1000 KZ
Re: Carb sync
Do this with the engine at running temp. You can usually get another turn or more out of the clamp screw then. A good habit to get in to when putting the carbs back on any time is to retighten them once the engine is warm.CYBORG wrote: re-tighten the manafold clamps. Good place to start
- RB
Re: Carb sync
Sticking slide, throttle cable pinch, vacuum leak, uhmmm...ah what else???
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- jdvorchak
Re: Carb sync
Actually that sounds pretty normal to me especially if the bike wasn't really up to temp when you did the sync. GL's take a while to get up to temp, like 15 minutes or so just sitting there idling. I rebuild a lot of carbs and after the first test ride I often have to reduce the idle speed.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- Zinc Member
Re: Carb sync
I did really heat up the bike before doing the carb sync actually, a good 30 minute ride, then idled for another 10 minutes whilst I got the gauges etc setup.jdvorchak wrote:Actually that sounds pretty normal to me especially if the bike wasn't really up to temp when you did the sync. GL's take a while to get up to temp, like 15 minutes or so just sitting there idling. I rebuild a lot of carbs and after the first test ride I often have to reduce the idle speed.
If it doesn't happen again then I'm happy.
1979 Gl1000 KZ
- jdvorchak
Re: Carb sync
Yep.. been there done that. Now the bikes I work on have usually been sitting for a few years. So I chalk it up to the bearings and everything inside, especially the carbs, got exercised and now it's running more efficient. Just my opinion but I've had it happen a few times and never had one again idled high.
2021 HD Triglide
John
2021 HD Triglide
John
- Zinc Member
Re: Carb sync
Many thanks, Will keep an eye on it, but not worry.jdvorchak wrote:Yep.. been there done that. Now the bikes I work on have usually been sitting for a few years. So I chalk it up to the bearings and everything inside, especially the carbs, got exercised and now it's running more efficient. Just my opinion but I've had it happen a few times and never had one again idled high.
1979 Gl1000 KZ
- 5 Replies
- 579 Views
Last post by flyday58
- 4 Replies
- 424 Views
Last post by Old Fogey
- 7 Replies
- 1733 Views
Last post by ericheath
- 5 Replies
- 252 Views
Last post by Steve81GL1100
