Hi,
I would like to add another light to the goldwing.
I would position it on the side of the bike.
To be honest, it's more about the look I would like to achieve than function.
My question is, can the battery deal with a second light?
I would think yes because I removed the radio, the speakers, etc, which must have drawn some current. So that unused currect could feed the new light.
I know a LED would use less current, but I can have a free headlight with a H4 bulb in it.
Anybody done this?
Thanks for your comments!
Adding a light
- Steevensi
Adding a light
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1982 Honda CB 750 K under construction
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1983 Suzuki GS770 rusting in a shed
1982 Suzuki GS750 in boxes
1982 GL 1100
1980 Suzuki A100
- BlueThunder
Re: Adding a light
Not quite. I mounted a 4 1/2" light on both sides on the engine case guards. This gives me 3 lights. Both are H3 and the headlight is a H4. I replaced all of them wih LED. Super bright, fit perfectly as they are replacement bulbs and STILL draw less current than one H4 bulb.
But to answer your question, having 2 Halogen H4 bulbs will tax the stock charging system at anything lower than 5K RPM.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- Steevensi
Re: Adding a light
OK. Good to know.
I'll look into LED bulbs.
Cheers
Cheers
The Black Bike
1982 GL 1100
1980 Suzuki A100
1982 GL 1100
1980 Suzuki A100
Re: Adding a light
LED would be the way to go as it requires less power. The biggest limitation is the stator output, not the battery. You might also changed out your tail/brake lights with LEDS as well, to lower the demand on the charging system
- Steevensi
Re: Adding a light
Brake light and flashers are already LED.
Thanks
Thanks
The Black Bike
1982 GL 1100
1980 Suzuki A100
1982 GL 1100
1980 Suzuki A100
- jdvorchak
Re: Adding a light
I had 2 H3 and an H4 on one of my 1200's and at idle the voltage would drop below 12v. If I'm not mistaken the 1200 had a bigger stator and put out more wattage. So on your 1100 I'm pretty sure that you'll kill your battery riding around town with that same setup.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
Re: Adding a light
yeah, the 1200 has more output..... gotta love it when I put the brakes on my 78 and the headlight dims
- 5 Replies
- 474 Views
Last post by Docvan
- 2 Replies
- 246 Views
Last post by Rat
- 12 Replies
- 1173 Views
Last post by Francis
- 3 Replies
- 296 Views
Last post by Shadowjack
