Can anyone read Japanese?
elwood440
Post by elwood440 »
I'm just curious if these markings on my cylinder heads mean anything. I had thought that the casting was the same for both right and left, but they say different things. "Left" and "Right?" See the pics below. I'm not even sure which way is up.
83 GL650i parked for maintenance
79 GL1000 "Bad Idea" current ride
I do all my spannering myself
"There's no excuse for the things I'm about to do"
SnoBrdr
Re: Can anyone read Japanese?
Post by SnoBrdr »
elwood440 wrote:I'm just curious if these markings on my cylinder heads mean anything. I had thought that the casting was the same for both right and left, but they say different things. "Left" and "Right?" See the pics below. I'm not even sure which way is up.
Maybe this can help: http://www.genkienglish.net/genkijapan/ ... panese.htm
78 GL1000 Original Owner 131k
gadelsperger
Post by gadelsperger »
There's an app for that!
(at least for an iPhone)
George in Rancho Cordova (Sacramento is a suburb) CA
Old Fogey
Post by Old Fogey »
The castings are the same for both sides. they only become left or right after machining. Since these are cast into the head, my guess is that they are core / mould number markings.
Old Fogey wrote:The castings are the same for both sides. they only become left or right after machining. Since these are cast into the head, my guess is that they are core / mould number markings.
They only become left or right after you install cams correct?. Machining is the same.
Old Fogey
Post by Old Fogey »
You are right Robin, I stand corrected!
calif wingnut
Post by calif wingnut »
This Help ~:<)
