Water Pump: Rebuild or Replace?
- manco
I have an 82 gl1100 that appears to have a weeping water pump. There is some dried coolant residue underneath the pump near the weep hole is why I think this. No major leaks or drips at this time though.
I haven't torn into the pump yet but did start doing some research into the project. I have seen whole pumps for sale as well as pump rebuild kits with seals and bearings. The OEM manual says to only replace the pump and not rebuild it. I have rebuilt a few auto steering and water pumps before with success that were also noted to be not rebuildable so I know these pump rebuilds are possible. I am looking for some input on the specific case of goldwing water pumps though. Has anyone rebuilt one before? Are special tools besides seal and bearing presses needed? How were the results?
As to why I would rebuild over replace its simply cause I am cheapskate.
1982 GL1100 Aspencade w/ California Sidecar
Re: Water Pump: Rebuild or Replace?
There have been several members who've done the rebuild, and at least one thread with step-by-step pics. I think it was within a build thread in the restoration forums.
Here's the link. Starts on post #29. http://www.ngwclub.com/forum/viewtopic. ... d&start=15 Good luck!
- hacksaw1945
I would not be to worried with dry coolant around the weep hole, but leaks or drips under the bike, would worry me. Before I torn into the pump I would drain the system and take off the bottom 90 going to the engine from the bottom of the radiator once off I would check how much play you have on the impeller. Go to shop talk and read up on water pumps first. My impeller had 1/2" play in all directions and was dripping. So ride some more and keep an eye on it. It is a job the takes time and you don't want to do it, if you don't need to.
1977 Honda GL 1000, 1982 Honda GL 1100I went naked, 1976 Honda LTD rough long range project, 1945 Indian Chief, 1947 Indian Chief, 1948 Indian Chief, 1958 Cushman Highlander, 1959 Cushman 3 wheel Mailister, 1966 Triumph TR6,
Just to add to the conversation, I have several good used ones, and at least one rebuilt one. They are easy to rebuild.
- manco
Thanks for the info guys. I did more research and found a tutorial on rebuilding the pump. It does look pretty straight forward to rebuild. I looked under my bike again today and it does look damp with a drip. My guess is its leaking about a drip or two per day as its dry on the floor underneath the bike. I am gonna tear into the pump to see what is going on. I am also planning a new thermostat and a radiator flush too. Maybe I will replace the hoses as well. I have a new cap already so that is a start.
Check for freeplay on the impeller first. If none or minimal, you may just need new o-rings and crush washers.
- jdvorchak
Glad to see you back online Roady
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
Thanks John. I lurk a lot but post little.
- RIP: cookie
If the bike's been sitting, ride it for a while .... might tighten up ....
- manco
I tore it down today. In the pump the seals are bad, bearings are bad and impeller is cracked. Also the cover had a bad gasket and corrosion around a broken oring for one of the water ports. I am just gonna have to rebuild all of it. Good thing I tore it down to find out the issues. Parts are on the way now. I think I can smooth over the corrosion with the jb weld. Its not too bad.
- BlueThunder
Seeing what a PITA replacing the water pump is, I replaced mine with a new one. All new o-rings, washers, etc. I don't want to do it again for another 30 years. There are too many tales on the lack of quality in rebuilt pumps for me to risk using one.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- manco
That's pretty much what I decided too. I hate doing things twice. Considering with the Goldwing pump water can get to the oil, oil can get to the water plus other issues possible if things go wrong doing everything new seems to be the best route. I am gonna do all new gaskets and seals in the transmission cover too while I at it. Fingers crossed for another 30 years once its done.
- 17 Replies
- 772 Views
Last post by robin1731
- 11 Replies
- 1054 Views
- 7 Replies
- 790 Views
Last post by gregforesi
