My battery on my '76 Wing died. What's the best way to check the charging system to make sure it working properly? Charging but not over charging.
Thanks!
Checking charging system....
- katmol
Old Naked Wings and SOHC 750's
- jdvorchak
Re: Checking charging system....
First charge your battery. Then while running at 2500 to 3000 rpm you should measure the voltage at the battery terminals. A good charging system will show 14+ volts but not over 15 volts DC. Normal charging is widely regarded as 14.2 VDC measured at the battery terminals with the engine above 2500 to 3000 and above rpm.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- katmol
Hey jdvorchak,
Battery charged, 3000 RPM's gave me 14.3 volts at the battery terminals. Now I can buy me a good AGM battery next season and not worry if my charging system has an issue.
Thanks for the help!
jdvorchak wrote:First charge your battery. Then while running at 2500 to 3000 rpm you should measure the voltage at the battery terminals. A good charging system will show 14+ volts but not over 15 volts DC. Normal charging is widely regarded as 14.2 VDC measured at the battery terminals with the engine above 2500 to 3000 and above rpm.
- jdvorchak
Very good. While we are on the subject. Have you heard of the 3 yellow wire white connector problems? There is a white plastic connector coming straight from the 3 yellow wire, which are the output of the stator. It is usually located right up next to the battery. On 1200's it's just to the left of the battery in the battery compartment. Your system seems to be working now but I still suggest you take that connector apart, clean the contacts with Electrical Contact Cleaner ONLY! Put some dielectric grease on the outside of the connector that pushes into the other connector. Then finish up by forcing dielectric grease on the back, or wire side, of both male and female connectors, to keep moisture from entering that back of the connectors.
2021 HD Triglide
John
2021 HD Triglide
John
- RB
Best way is to install a volt meter and you can watch it all the time. If things start to go south you'll know it before you get stranded.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- 21 Replies
- 962 Views
Last post by gdonlo04
- 3 Replies
- 466 Views
Last post by Track T 2411
- 10 Replies
- 885 Views
Last post by Toehead
- 8 Replies
- 527 Views
Last post by Easter
- 8 Replies
- 560 Views
Last post by adecood
