Converting from electronic ignition to points
- Toehead
Re: Converting from electronic ignition to points
+1
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
I will bypass the ballast for now and see what I get. I got the higher resistance coils planning to use the martek ignition, but after looking at the wiring etc decided against it. Might revisit an electronic ignition at a later date so the coils should be fine then. I will report back.
Also I'm going to check everything according to the helpful link whiskerfish posted earlier in the thread.
1976 gl1000
Bypassed ballast on the coils. Switch on I have 12+ volts. Cranking at 10+ v now. I think it might work. Thanks for the help
1976 gl1000
- 14 Replies
- 845 Views
Last post by SnoBrdr
- 5 Replies
- 270 Views
Last post by twistedinjun
- 9 Replies
- 793 Views
Last post by elslimdiablo
- 4 Replies
- 796 Views
Last post by ericheath
