Inside a timing belt tensioner pulley
Goboy
My Album: https://www.ngwclub.com/forum/viewtopic ... 30&t=60678
Post by Goboy »
When I was installing new Gates T42015 pulleys on my 78, I cut open the old original style pulley to see the insides. Someone may come up with an idea on how to the stock shaft to mount new pulleys. In the photos I have hacksawed the shaft off of the pulley mounting plate. The shaft size is 17.99mm O.D. and15.75 mm in grooves and 25.20mm high.
Original tensioner pulley parts.jpg (209.04 KiB) Viewed 1096 times
tensioner pulley shaft.jpg (101.48 KiB) Viewed 1096 times
You're too small to ride a hog Billy!
Mike
1978 GL1000
Previous bikes: 05 Yamaha FJR 1300, 79 Suzuki GS 1000, 75 Yamaha XS 650, 73 Kawasaki S2 350
BikeMaine
Re: Inside a timing belt tensioner pulley
Post by BikeMaine »
Interesting
Kevin
1982 GL1100A
Rednaxs60
Post by Rednaxs60 »
There are a lot of threads on doing this timing belt tensioner bearing mod. Did the mod on my '85 LTD because of age more so than anything else. It was also less expensive than OEM idlers. Cost was $80.00 CDN to do the mod versus $200.00 for OEM idlers.
Here is my rebuild:
Timing Belt Tensioner Rebuild - Just finished this rebuild. I had seen it in this and other forums, and was not going to do it because the idlers didn't feel that bad; however, I'm not one to shirk a challenge. Ordered the idler and it's a Gates T42105. Went to the son-in-law's and cut the idler off and punched out the old stud giving me an opening of approximately 0.54". The opening is countersunk on the back so I surmised that a countersunk head bolt would self-align when tightened up because the new idler would "sit" flush against the base plate. I used a 6 mm hex drive and 17 mm socket.
This picture shows the parts used with the old idler as well. You will notice that the bolt, 10 mm by 25 mm, has a flat countersunk head that should self-align when tightened.
Old and new parts.jpg (126.71 KiB) Viewed 1060 times
This picture shows the countersunk hole on the back of the base plate that the bolt will fit into.
Base Plate countersink.jpg (138.61 KiB) Viewed 1060 times
This picture shows the new idler installed and the new bolt "proud" of the base plate.
New idler installed on base plate.jpg (134.33 KiB) Viewed 1060 times
This picture shows the tensioner with the new bolt flush with the back of the base plate. I used a 24 tooth hacksaw blade to trim off the excess bolt head so it is flush with the base plate. The hex hole is still 1/8th inch deep so I will be able to replace later on if necessary.
Bolt trimmed to base plate - 1.jpg (126.27 KiB) Viewed 1060 times
Bolt trimmed to base plate - 2.jpg (123.39 KiB) Viewed 1060 times
On to post #2
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
Rednaxs60
Post by Rednaxs60 »
Post #2.
This picture shows the front of the tensioner.
Tensioner with new idler installed.jpg (144.47 KiB) Viewed 1059 times
This picture shows the finished tensioners.
Finished new timing belt tensioners.jpg (137.64 KiB) Viewed 1059 times
I was pleasantly surprised how easy this modification is to do with minimum tools. Items:
hacksaw
Punch/chisel - to remove old stud after hacksaw used to remove old idler
17 mm socket
6 mm hex drive
10 mm by 25 mm flat countersunk bolt
nylock nut with flat washer
Gates 42105 idler
Total cost for this mod is approximately $90.00. I did not need to use a 1/2 inch drill bit that I bought specifically for this, so the resulting would have been $84.00, significantly less than 2 new timing belt tensioners from mother Honda.
Cheers
Ernest
2008 GL1800 (sold)
5speed
Post by 5speed »
Rednaxs60..do you have any concerns that cutting the remaining head off the bolt weakened it in regards to side tension on the bolt?
It looks like the plate is thick enough to allow a deeper counter sink for the bolt.
There is actually some room behind the plate for a thin bolt head. I used Bolts and ground them down some but no where near flush.
Rednaxs60
Post by Rednaxs60 »
5speed wrote:Rednaxs60..do you have any concerns that cutting the remaining head off the bolt weakened it in regards to side tension on the bolt?
Not at all. There is still a lot of meat on the bolt head and the countersink is a lot as well. There should be little if any side loading on the bolt once it is tightened/torqued. The bearing sits flat against the mounting plate so there has to be a lot of stress from the timing belt to do any side loading. Timing belts aren't supposed to be that tight. Had mine in for 15,000 Kms and no issues to date.
I used nylock nuts so that in the future, if I had to replace the bearings it would be an easy exchange.
Cheers
Ernest
2008 GL1800 (sold)
5speed
Post by 5speed »
tks for the response. I will be doing this upgrade in the near future.
Rednaxs60
Post by Rednaxs60 »
When you do this mod and cut off the old pulley with a hacksaw (faster and cleaner than using an angle grinder), punch out all of the old bolt that held the old pulley on. Will give the same look as in my picture in my previous post.
Cheers
Ernest
2008 GL1800 (sold)
This certainly looks easy, I don't know where I got the idea that it was really involved and needed special tools... I might just give it a go for the sake of peace of mind.
Goboy
Post by Goboy »
On my 78 I ground about half of the head flush (there's a small step on the head) to insure that when the spring applies tension toward the bolt there won't be interference. You could also grind a little off that dog leg bracket or a combination of the two. I can just get the new belts on without too much trouble. It was much easier than my first time, practice helps! :orange
Idler pulley mount plate back view 02.jpg (155.46 KiB) Viewed 994 times
Photo of them installed on the bike. The hose is so I can warm up the bike and readjust the belt tension while the bike is warmed up. The engine can expand enough to make the belts too tight, so bring it up to operating temp and see if you feel a difference in the belt tension. One other thing I found while warming up the engine I noticed the rt. timing sprocket was wobbling, turned out to be a bent sprocket, put another used one on now its fine. Lucky! as I was worried it was the cam snout. The bike had been down at some time in the past, as the bottom of the right crash bar was ground flat. I also found that the cover plate behind the sprocket was bent and had cracks and the rt radiator wing has been repainted.
Idler pulleys and hose.jpg (249.11 KiB) Viewed 994 times
Mike
1978 GL1000
Beetleman
Post by Beetleman »
I did this same mod when I changed my head gaskets. I used a port-a-band saw at work to cut the original studs off.
I got the old stud out by centering the stud over a size 18 socket. I then took a smaller socket that was slightly smaller than the stud size and used it like a punch on the other side and the stud head popped out pretty easily.
The gates rollers look like they're made out of better materials than the stamped steel originals. I would hope that they will last quite a bit longer than the originals.
1978 gl1000 Not Nice bike.
1978 gl1000
Taking 10 minutes every day to use the bathroom at work is equal to one week's vacation.
Beetleman wrote:snip................ I would hope that they will last quite a bit longer than the originals.
I don't know. 40 years is a long time. ;)
dartman1962
Post by dartman1962 »
Hi, I was just reading your post. you mention the Gates P#42015 first then down in your other comments you
mention the P#42105. So is the P#42015 or 42105?
Thanks Dartman.
1975 Honda Goldwing,
2000 Honda Ace Tourer
Let's R&R, Rev it up & ride!
Image Image Image
The day I purchased the loaded wing for the sum of $20.00. Nearly finished 1975 NGW way better naked!. My 2000 1100 Honda Ace Tourer. Next project?
