Needing to replace the Stator...Update!
- wingrider
Hey all,
I fella I know recently brought me his 1200 standard to check stator output. It's determined that the stator is bad, which prompts my question.... Who makes the best replacement? He is only looking to change it once.
I see Randakk sells one... anyone have any experience with it?
Thanks for any help!
Re: Needing to replace the Stator...
Have heard good stuff about "Ricks" but I have not used them personally. I would stay away from Saber, Barracuda and DB electrics.
Or possibly Caltric as well. About this time last year I replaced a stator for a friends 1200 Aspy, he had already purchased the Caltric stator before saying anything to me so I went ahead and put it in and it worked just fine at first but that only lasted for maybe 6 months and it died again. My friend got fed up with the bike and sold it and now the new owner wants me to replace it again, problem is I really don't want to because I've already got enough projects keeping me busy. In the meantime though I've already forewarned about cheap price/quality statorsWhiskerfish wrote:Have heard good stuff about "Ricks" but I have not used them personally. I would stay away from Saber, Barracuda and DB electrics.
Scott
- gregforesi
I started to type a rant, but I think I'll just say to stay away from Electrosport too.
2006 GL1800 (Brutus Maximus)
Used to be several OEM NOS stators on ebay.
- wingrider
Thanks for the warnings! Greg, I recalled you had trouble with one...the name is all I needed to know.
eBay seems to be full of the cheap ones. There are a couple OEM ones, but they are $400, as they are for the FI bikes.
- salukispeed
4 + years 15,000 miles on a new OE and going strong. Paid around $250 for it then. Money seems well spent now. Do the starter clutch pins, springs, and good inspection also clean out debris around the scavenge oil pump too while in there.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- wingrider
Well, we are going to be putting in a Randakk stator in the 1200. Owner wasn't to keen on spending $350 for the OEM, and it appears it might be no longer available, so the Randakk one will hopefully work out!
- Dirty Dave
I've been using an Electrosport for the past coupla years without problems. Charges at 14.1 volts consistently.
1978/9 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1997 Honda Valkyrie
- jdvorchak
Strange that you lost the new stator. The original problem with the 1200 was the insulation they used and only in 84. I'd be surprised if that first bad stator was original OEM as Honda replaced thousands of stators back in the 80's. I'd be looking at the regulator/rectifier and the white connector mod on the next replacement stator. When the regulator goes it sometimes takes out the stator, but not always! You may think the stator is bad but until you do the resistance and VAC test you won't know for sure. I can't tell you how many times I've worked on a bike with a "bad stator" only to find the white connector or the R/R was bad and the stator turned out good.
I guess I'm saying before you pull the engine for Stator replacement, make absolutely sure it's not a simple wiring issue with white 3 pin connector.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- wingrider
Appreciate the concern, unplugging the stator (which we had cut the wires to be sure we had good connection) and checking the three leads with my meter set on the AC setting scale was set on 200, and it was reading 16-20 on all three lines. From what I have seen, the numbers should have been high 20's to low 30's at 1000 rpm, and 60-70+ at 3000 rpm. This one doesn't do that. It did ohm out ok, but that was about it.
I did plan to check the regulator/rectifier to be sure it was good before the new stator goes in. This bike was new to him last fall, and he bought it at a small dealer, so the history really isn't known on this one.
you did measure it on the AC scale, right?
- wingrider
Yep
- wingrider
Re: Needing to replace the Stator...update!
Well, finally had a bit of time to get the engine out of this 84, and take a look at the stator. I would say this one is about done. What do you all think?
Looks burnt and coating is flaking off...
- salukispeed
Re: Needing to replace the Stator...Update!
Thats what my original looked like and the white plastic connector had melted and all three connectors were shorted together. I figured the short was the cause of the stator failure
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
- 20 Replies
- 1088 Views
Last post by JSBail
- 59 Replies
- 2234 Views
Last post by rcmatt007
- 49 Replies
- 2432 Views
- 3 Replies
- 218 Views
Last post by bonestock3
