Yes I reused it.brianinpa wrote:The one that connects both spark plugs together and covers the holes.
SO, I changed my plugs/wires/boots
- BikeMaine
Re: SO, I changed my plugs/wires/boots
Kevin
1982 GL1100A
1982 GL1100A
- jdvorchak
I'm pretty sure that rubber cover was more cosmetic than functional. It doesn't fit well enough to actually seal anything. Also I found it a pain to deal with when just trying to pull the caps off to get at the spark plugs. That being said I wouldn't remove it if it were in good shape. Just my opinion.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
About the only good thing I can see with the big cover is that it keeps debris out of the spark plug wells. I always just blow them out with air and/or PB Blaster, and make sure the drain holes are open, and forget about using the cover. My 2 cents...
- brianinpa
Mine were deteriorated so I tossed them.
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
- RIP: cookie
Have to make sure the drain holes don't get plugged up next time it rains ....
- BikeMaine
The rubber covers on mine are in great shape so I reused them. If they stop one little pebble or some sand from getting in there, they're worth the trouble in my opinion.
On a positive note, My bike has never run so well. Smooth and great throttle response now.
Oh, and I gained 4mpg.
Kevin
1982 GL1100A
1982 GL1100A
- mcgovern61
Back in '08, I replaced my wires with these grey Dyna wires that I got from Crescent Moon Cycles way back then. They work terrific and I have never had an issue riding through serious rain storms like I did with the original wires.
- Engine Color 001.JPG (146.19 KiB) Viewed 116 times
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
- BikeMaine
Gerry,mcgovern61 wrote:Back in '08, I replaced my wires with these grey Dyna wires that I got from Crescent Moon Cycles way back then. They work terrific and I have never had an issue riding through serious rain storms like I did with the original wires.
Nice clean bike you have there man. I like the grey on the engine case.
Kevin
1982 GL1100A
1982 GL1100A
- mcgovern61
Thanks Kevin!
Gerry
- BikeMaine
