ok, so after i finally finished my waterpump and got it going with no leaks(83 gl1100) i took it out for a test spin and the shifter is sticking....that is to say that when i shift a gear the lever doesnt return to center...i have to physically move it back with my toe in order to get to the next position to shift up or down....so.....did i get the neutral switch hooked back in wrong somehow maybe? or is it some other thing.....saw on here one post about the gasket being to thin, but that was the only post i could find about the issue....any ideas or experience with this?
thanks!
sticky shift lever after water pump replacement
Re: sticky shift lever after water pump replacement
yep. Cheap aftermarket gaskets or over tightening of the screws or reusing a old gasket will cause this. there is only a hair of clearance between the shifter mechanism and inside of the front cover.
I assumed as much.
Figure I got the neutral switch on goofy, or its the gasket.
I already ordered a new gasket from partzilla.
I was careful to tighten the bolts to 9 fp...so i thought.
Oh well, looks like I'm going back in....but at least the water pump is right!!!
- tlbranth
Ted - something I picked up along the way - make sure the hole in the neutral switch is down so the switch can drain. Nothing to do with your shift problem but since you're messing with it.........
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- JBz
tlbranth wrote:Ted - something I picked up along the way - make sure the hole in the neutral switch is down so the switch can drain. Nothing to do with your shift problem but since you're messing with it.........
starting in 82 they have a neutral switch under the front cover not on the side. My guess if its working and showing neutral You got it right jb
- Sandy
Same problem, my solution.
https://www.ngwclub.com/forum/viewtopic ... 31#p644031
Sandy I sent you a pm
- 3 Replies
- 301 Views
Last post by John Schmidt
- 7 Replies
- 848 Views
Last post by OldRider2
- 7 Replies
- 299 Views
Last post by EdK
- 14 Replies
- 414 Views
Last post by CYBORG
