I'm thinking about replacing my ignition switch. Nothing wrong with the original part. I got a set of Interstate bags and a complete lock set over the winter and now have 2 keys to deal with -- one for the bags and the original for everything else. I would kinda like to go back to a single key for everything... I have not electrically tested the "new" switch, but it appears to be in good condition and came off a running bike (so said the ebay vendor I got it from -- a bike salvage place in Michigan).
According to the Honda shop manual, replacing the ignition switch starts with "remove the instrument cluster..." Really? Looking at it, it seems like it ought to be accessible by removing the headlight bucket. Haynes says to remove both the bucket and the cluster...
Has anybody else done this swap? Is it do-able by just removing the bucket or do I need to budget time to pull the cluster too?
Thanks
New ignition switch
- Steve81GL1100
New ignition switch
Steve
1996 BMW R1100R
1996 BMW R1100R
Re: New ignition switch
I haven't done it on an 1100, but on 1000's it comes out through the bottom and the bucket is in the way. The manual writers may have felt it's easier with the cluster pulled up and back instead of working from underneath. With a fairing will make a difference. I think it's bolted to the underside of the upper triple tree. Removing the triple tree would expose everything it I wonder about having enough wire and cable slack to reach for that. Or if air forks will allow it.
You should be able to access it by just loosening the bucket. It does bolt on from the bottom. You'll have to play around getting it out through the spaghetti of wiring and cables, though.
- chewy999
I've just changed mine on the advice of a guy who is helping with my over charging problem. Just loosen the headlight bucket and the ignition switch is just held on with two bolts. Undo the bolts and disconnect the socket and it comes out! My old one may have been the problem as the sense (black) wire connection was quite corroded.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Bingo on that, chewy.
- brianinpa
The could be another option...
Get Roncar to make one key that works for the ignition AND the bags.
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
- 13 Replies
- 1397 Views
Last post by Mojogameplay
- 12 Replies
- 1240 Views
Last post by jdvorchak
- 350 Views
Last post by sphen
- 12 Replies
- 560 Views
Last post by Irishman1
