C5 Installation Question
- delling3
Re: C5 Installation Question
Thanks for tuning in to my continuing saga.
So, again I have a '78. '78 and '79 have "junction box" located at the front left side of the shelter. Replaces all of the spaghetti that is the wiring on the early wing with automotive style connectors, instead of all those individual bullet connectors.
After talking with Paul at C5, I was going to run power to the coils direct from the battery. Meanwhile, I was planning to run power to the ignition module from the Black/White wire that fed the coils on the OEM system. On the '78, the black/white connects to the junction box, and then exits from another connector to the coil harness. I figured I would simply cut the black/white wire off at the coil, tape off the balance of the wires in the coil harness, and splice the ignition module supply wire to the black and white. All sound good so far?
The OE system was working fine when removed. Now, measuring voltage between the connector on the junction box, and ground I see 0 VDC. Power to everything else on the bike. Obviously I missed something very fundamental in the wiring diagram. Where did I go wrong?
Again, thanks in advance for your help.
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
Why don't you just run it to the battery live the directions say.delling3 wrote:Thanks for tuning in to my continuing saga.
If I'm understanding your issue.
78 GL1000 Original Owner 131k
- flyin900
I believe the black/white wire is switched through the on off run switch on the right hand switch setup, so do you have the switch in the run position? Just guessing from memory... and I don't remember what I had for breakfast today. The solid black wire carries the constant 12VDC, so check your run switch.
Current Bikes:
- delling3
Instructions suggest running coil power direct to battery, but module power to a lead that is switched by ignition switch. I went with Black/white to preserve kill switch function. Keyswitch "on" and killswitch to "run". O VDC at connector.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
- flyin900
So if you look at the colour schematic for wiring for your bike in the Tech Section it shows that the power into the kill switch is by a black wire with possibly a brown stripe on the 78 year, or on the earlier models it is a solid black wire with brown coloured rings at key visible points on the harness to denote a black/brown wire designation.
The wire runs from the out connection on the ballast resistor by the coils and will supply either 12VDC when the starter button is activated, or reduced voltage when in the run position and the motor running. The opposite side is fed by a black 12V wire connected off the main key switch.
It you want to do some troubleshooting there seems to be a disconnect somewhere not letting the voltage through to the kill switch circuit. Check the ballast resistor if it is still in your circuit, if it is removed for the C5 system did you connect those two wires to allow voltage to flow through the old circuit to the kill switch?
Current Bikes:
- delling3
Well, little by little, I am getting there.
Flyin900 spotted the "missing link". C5 instructions mention removing the ballast resistor, but not what to do with the leads. After tying the leads to the ballast together, I have voltage where it should be.
Got everything buttoned back up, and set the timing as per the instructions. The bike fired up and settled into a nice idle with a lot less fuss than before. Great, right? I shut the engine down, and went about tidying up a few things. After 20 or so minutes, I went to restart, and then things got real interesting. The bike struggled to start, didn't want to idle (choke or no choke, wouldn't take any throttle), the engine was kicking back, and there was a serious clatter coming from the bottom end. Sounded (to me) like a severe case of out-of-sync carbs, except, how does a set of carbs go out of sync sitting for 20 minutes?
What the heck? I rechecked the timing on the C5 - spot on. Thoughts?
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
Setting timing at T1or F1? Should be T1 with C5.
- delling3
T1.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
- delling3
Like I said, first time I started it went fine. Sat for 20 minutes, and suddenly all heck broke loose.
I tend to think the worst first - timing belt skipped? Brand new belts this past winter - only a couple hundred miles on 'em.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
- brianinpa
What are the condition/age of the plugs?
Brian
ADC(AW) - US Navy Retired 1983-2003
If you aren't having fun doing it, find something else to do.
1984 Standard - 18,000 miles - Naked... the way it should be
1987 Interstate - 62,000 miles - Resurrected from the rust bucket
It would seem to me that only a few things could change in that time. I would go through the electrical connections you've made looking for something loose, and check for any fuel related issues. If you can keep it running at all, I'd also check for spark. It's gotta be something simple. My 2 cents...
- delling3
Plugs are brand new.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
Check the battery voltage. Both key on and off.
When I suggested to check for spark, I meant it as a means to isolate the problem cylinder(s) and eliminate or identify that possibility. No offense, but even a new plug can fail or be defective out of the box. Just saying...
- 4 Replies
- 345 Views
Last post by 5speed
- 11 Replies
- 1588 Views
Last post by Sidecar Bob
- 8 Replies
- 848 Views
Last post by heraldhamster
- 6 Replies
- 403 Views
Last post by Dirty Dave
