1982 carbs
- wayneperry
1982 carbs
hi all, bringing this topic over from member restorations. picked up a used 82 standard. PO tried to rebuild the carbs. Bike was pouring out fuel from plenum and he could barely get it started with full choke. II tore into in to it suspecting carb to plenum o rings and sure enough, not in the right placement. All other replacement parts looked great. set floats, as they were off a little, and put back on bike. No leaks, starts and purrs at idle. But, twist the throttle and it bogs down and dies. Sync on carbs look perfect. spray carb cleaner all around, no apparent leaks. I've pulled these babies out, torn down, rechecked every darn thing, 6 times, and I cannot for the life of me figure this out. Carb/break cleaner in every orifice . Nozzles are squirting fuel fine. What could I possibly be missing??? accelerator pump looks like it was replaced with all the other carb parts. Don't think this was a Randak kit, could this be a crummy rebuild kit? I'm really stumped. I took a known carb good carb rack off an 83, put it on the 82 and it runs perfect. So i'm missing something.. Any suggestions at all??? I've rebuilt a couple of 76s and had no problems. every dismantle, clean check readjust leads to same conclusion. throttle/bog down
sorry for the long story. Wayne Also, I have a 79 rack in good condition, can I put it on the 82?
1978 GL1000
Re: 1982 carbs
On first reading I was going to say check your valve adjustment then I got to the part where the 83 carbs worked well. I do not know much about 1100 carbs. Are they the same between the years?
- wayneperry
Re: 1982 carbs
thanks, yes the 82 and 83 are the same. wondering about the metering rods. If they were changed out with he wrong length, I am running out of ideas.
1978 GL1000
- RB
Re: 1982 carbs
Yep, all 1100 the same..pull the plugs after a bog down all wet?? or one or all, sooty, black, dry what?? But sounds like flooding if bogs when apply throttle..wrong size main jets??? on all four?? are the jets original OEM or replace from a kit..lots of kits have the wrong size jets or poorly spec-ed jets.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Re: 1982 carbs
I didn't see anything about polishing the slides and making sure they are working smoothly.
Usually a bog is a lean condition. Have you tried running the carbs with the choke partially on?
- wayneperry
Re: 1982 carbs
first thing I did was suspect sticking sliders. They were sticking a little. I cleaned and polished, slide much better, but didn't make a diff. Yes, the more choke seems to allow throttle up. what are the jet specs? I'll look at plugs tonight. Thanks for all the feed back. I was wondering about the plastic donut and o ring on the sliders. pulled the donuts out of sliders to check the o ring [ which should have been replaced with rebuild kit } and two came out with fingers, too easy, compared to the other two which I had to use needle nose plyers. So, 2 felt like new rubber o ring and 2 felt like old used rubber o rings. Am I searching too deep here? how important would these be? Also the clamps on the intake manifolds are completely closing but carb spray around them didn't change much when bike idles, which it idles very good. Back out to the garage for more dissecting tonight. wayne
1978 GL1000
- mcgovern61
Re: 1982 carbs
I did a set of '81 carbs last winter and had the same issue. Bottom line, it turned out to be the port on the accelerator pump cover. Take the cover off and be sure you can blow carb cleaner through it at the little square. Here is the pic from Roady's great tutorial:
If you cannot get carb cleaner through the square, then it is plugged. I had to spray cleaner in and then work a guitar string around each side to free up the debris.
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
Re: 1982 carbs
But, he says, "Nozzles are squirting fuel fine.". I don't think that's the issue.
Re: 1982 carbs
wayneperry wrote:thanks, yes the 82 and 83 are the same. wondering about the metering rods. If they were changed out with he wrong length, I am running out of ideas.
Possible, or they could be larger diameter than stock too. That would cause a lean condition. Just for testing purposes, for now, try putting a #4 washer in the needle (all 4). See if that helps/changes/makes it worse.
And I do mean a #4, not 4mm.
Re: 1982 carbs
Stock air box and filter installed while doing all of this right?
- wayneperry
Re: 1982 carbs
yes, air box installed. I'll try the washers next, thanks Robin1731. I'll let you guys know
1978 GL1000
- wayneperry
Re: 1982 carbs
So, having hard time finding #4washers ! tried hardware and Napa, no luck yet.
1978 GL1000
- Sugs
Re: 1982 carbs
You guys have an Ace Hardware? I find they are the best for nuts and bolts unless you have a specialty store.
_______________________
'79 Honda GL1000 Goldwing
Re: 1982 carbs
Or Fastenal or Grainger.
- wayneperry
- 13 Replies
- 859 Views
Last post by Track T 2411
- 12 Replies
- 1066 Views
Last post by wren337
