Freeing up frozen locks?
So my locks for my helmet holders and bags are frozen solid. Already tried a little wd40 and nothing. Any ideas?
2004 Saturn Ion Redline Coupe
2007 Saturn Ion Coupe
2001 Jeep Cherokee Mud Truck
1979 Honda GL1000
1978 Honda CM185T
1979 Honda GL1000
1978 Honda CM185T
- salukispeed
Re: Freeing up frozen locks?
Acetone and trans fluid instead of WD and lots O patience.. Another product I am a huge fan of is KROIL but the acetone and trans is very good. Patience and try a little each day . do not force or you will loose
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
So just kinda drip it in there and let it sit?
1979 Honda GL1000
1978 Honda CM185T
1979 Honda GL1000
1978 Honda CM185T
- Sagebrush
Yup, IIRC the acetone transmission fluid which has been used with amazing results with various folks on this forum is a 50/50 mix. BTW WD-40 isn't a very good rust solvent.So just kinda drip it in there and let it sit?
- tlbranth
It's actually not too hard to disassemble the helmet lock. It'd be easier to loosen things up if apart. But the acetone/atf mix is a pretty good 'liquid wrench'. After it's free, I'd give it a squirt of Lock-ease.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- warhead_71
I have an old crock-pot that I bought for $5 from a garage sale that I use in the garage to cook parts overnight. Vinegar helps remove rust. Or add lemon juice to remove grease, grime, old lacquered fuel. I cooked some dirty old CB200 carbs and they came out spotless.
- jdvorchak
I use PB Blaster for all kinds of stuff around the shop and home. I squirt a bit right into the lock and some on any moving part I can see. It penetrates well and leaves behind an oil that smells like Marvel Mystery Oil. I think it's a lot cheaper and easier to find than Kroil.
I've used acetone and Auto trans fluid before but found it no better or worse than PB Blaster.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
Great idea! Likewarhead_71 wrote:I have an old crock-pot that I bought for $5 from a garage sale that I use in the garage to cook parts overnight. Vinegar helps remove rust. Or add lemon juice to remove grease, grime, old lacquered fuel. I cooked some dirty old CB200 carbs and they came out spotless.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
On caution on the lemon juice; it may discolor/darken some metals, especially carb bodies (by experience). I like the crock pot idea, though!
- jdvorchak
I like the crock pot idea. What do you put in the pot for a cleaner? I imagine water and some Pine-Sol?
2021 HD Triglide
John
2021 HD Triglide
John
- scootsx2
I agree , it does sound like a good idea, especially if you don't have an ultrasonic cleaner with a heater function.jdvorchak wrote:I like the crock pot idea. What do you put in the pot for a cleaner? I imagine water and some Pine-Sol?
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- jdvorchak
I've been wanting a new slow cooker for a while. The old crock pot I have must be 20 or 30 years old and only gets up to 200 Deg F.
2021 HD Triglide
John
2021 HD Triglide
John
- warhead_71
Yes too much lemon juice will discolor/darken aluminum. I only add a "splash" of lemon juice, a good squirt of dish soap, then fill the rest with water in my 3-quart pot. Seems to do the trick on carbs, and I don't notice much color change. Plain water also works, it just takes a lot longer to break down the gunk.
I started using a Crock-Pot because I have a 100-year-old house that had solid wood doors that I was stripping and re-staining to original... they had been painted over, maybe 5-6 coats. And they painted over all of the hardware too: brass hinges and brass/glass doorknobs.
I can throw the hardware in the Crock-Pot on "high" overnight and in the morning the old paint just wipes/slides right off in big pieces -- minimal scrubbing with a plastic brush. I preferred this to my other options: using a heat gun it's really hard to handle brass when it gets hot, and the paint just gets gummy; using chemical strippers might etch the brass, is expensive, and stinks; using scrapers/wire brush makes a lot of dust and leaves swirls/scratches all over it.
** Just checked out YouTube and I see this guy is using anti-freeze... looks like it works wonders on old RC model airplane engines. And he even strains out the dirty anti-freeze when he's done to re-use it over and over.
https://www.youtube.com/watch?v=cCTQK9aKpr0
Be wary of how hot you get the lemon juice mix. I boiled a set of carbs in a lemon juice/water mix, they came out pretty good however the boiling lemon juice stunk the entire house up. If I ever try it again I'll be doing it outside.
Scott
- 6 Replies
- 614 Views
Last post by sphen
- 14 Replies
- 518 Views
Last post by Old Fogey
- 34 Replies
- 3134 Views
Last post by Oldtech
- 6 Replies
- 330 Views
Last post by Shadowjack
