Rotor cover broken? Can I still ride?
Well as the subject says, can I ride with this off? Is there oil in there? I was adjusting my valves and totoally spaced and was trying to rotate the engine but stupid me forgot to take off the cover!!! Maybe it is ok to ride just not recommended? Or don't ride it? I don't even know what's in that area, I just know you turn that and your belts move. Sounds important. Thanks guys
Oh also here some pics as to what I'm saying.
- IMG_1056.JPG (149.03 KiB) Viewed 185 times
- IMG_1057.JPG (117.14 KiB) Viewed 185 times
- IMG_1060.JPG (166.27 KiB) Viewed 185 times
1980 Honda Goldwing Gl1100
-I ride naked-
This Is My First Motorcycle
Portland, Oregon
-I ride naked-
Portland, Oregon
Re: Rotor cover broken? Can I still ride?
The amount of oil flow back there has been debated several times. I believe that it is a mist but yes there is oil back there. No I would not ride it. It is the same plug used in hundreds of other honda applications and should be a shelf item in any honda dealer. Do not tighten it. Should only need to be snug, the oring will hold it in place.
good to know I will see if the dealership has this plug, thanks for the quick reply.Whiskerfish wrote:The amount of oil flow back there has been debated several times. I believe that it is a mist but yes there is oil back there. No I would not ride it. It is the same plug used in hundreds of other honda applications and should be a shelf item in any honda dealer. Do not tighten it. Should only need to be snug, the oring will hold it in place.
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
Chang_G_Wing wrote:good to know I will see if the dealership has this plug, thanks for the quick reply.Whiskerfish wrote:The amount of oil flow back there has been debated several times. I believe that it is a mist but yes there is oil back there. No I would not ride it. It is the same plug used in hundreds of other honda applications and should be a shelf item in any honda dealer. Do not tighten it. Should only need to be snug, the oring will hold it in place.
awww man my dealership claims they don't carry....errrrr
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
Mine was broken when I removed it to do a project on July 1st. Since my GL is my primary transportation I rode until Thursday that week when a new one arrived. There was some oil that came out back there but it wasn't a large amount at all but still required a little more cleaning. I think I got mine on ebay for around $15 new.
To help you in your search, it's called a Tappet Valve Cap Adjustment Cover
1982 GL1100 Interstate
If you listed your location someone close might have one.Chang_G_Wing wrote:Chang_G_Wing wrote:good to know I will see if the dealership has this plug, thanks for the quick reply.Whiskerfish wrote:The amount of oil flow back there has been debated several times. I believe that it is a mist but yes there is oil back there. No I would not ride it. It is the same plug used in hundreds of other honda applications and should be a shelf item in any honda dealer. Do not tighten it. Should only need to be snug, the oring will hold it in place.
- Lucien Harpress
^Pretty much this. That cap was used on a LOT of stuff. Heck, I'm pretty sure I have a 1972 CB750 motor in my back yard had has eight of them on it (I'll have to confirm).
If you can't get something local, let me know. I may be able to send you something. (PM me, otherwise I'll forget)
Lucien Harpress wrote:^Pretty much this. That cap was used on a LOT of stuff. Heck, I'm pretty sure I have a 1972 CB750 motor in my back yard had has eight of them on it (I'll have to confirm). They are the same.
Your dealer doesn't keep much in the way of spares, does it? See if this link works:
http://www.partzilla.com/parts/detail/h ... 0-000.html
- hoganJr
If that's all that prevented me from riding I'd clean it real good and duct tape it.
HoganJr
HoganJr
1991 GL1500
- chewy999
I would wait until you can get the replacement part, and also change the O ring. I had one break on me, as I was doing it up the main part sheared leaving the threaded portion in the case! I hadn't even got to the 'snug' bit!
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- RB
I have a couple $5 plus shipping..put your location in your Id
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Ive looked all over, can't seem to find where to put in my location. So I just put it in my signature. Portland, Oregon if someone has one. Thanksrobin1731 wrote:If you listed your location someone close might have one.Chang_G_Wing wrote:Chang_G_Wing wrote:
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
