temperature and radiator wings
Re: temperature and radiator wings
Another factor which might help them cool better is removing the heat shield behind the radiator. As Roger mentioned there aerodynamics come into play. I have wondered how much the heat shield slows the air down as it passes through the radiator and then hits a wall and has to make a near right turn to exit.
I'm not up on aerodynamics, so I can't say, but the one I have without the heat shield runs cooler. I do have the wings on it.
Removing that heat shield can really impact the operating temp of the carbs and could have negative effects. I have not done it so I can not speak from experience but it is there for a reason I think??
zipster
Post by zipster »
Removing the heat shield would change the temp the carbs see, and so could affect performance.
~Don't skin yer knuckles whatever you do.
1977 GL1000
1986 BMW K100RS flying brick
1975 Yamaha RD350
1978 Vespa P200e
1979 Lambretta Jet200
1986 Honda Helix
and probably put more heat on your legs
Easter
#20
Post by Easter »
Well here I go again. I always leave the heat shield off. If there is any effect I am too (pick an appropriate word) to notice. Seem to run good, doesn't run hot, doesn't make my legs hot, and makes engine and carb changes a heck of a lot easier. Only have about 10 or 15 thousand miles on the various bikes so maybe it is too soon to be sure.
83 GL in process :IDTS:
#21
I'm with Easter. I do not have the shield on ether of my bikes. That DOES let the air flow better thru the radiator. Carbs ARE easier to remove, and work on. And there is a little more heat on my legs, but not enough to be a problem.
RB
#22
Post by RB »
Well compromise..cut some vents in the heat shield that directs the flow out left and right to avoid the carbs..somewhat..;>)!!
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
#23
I think more is gained by the air blowing across the engine block. The heat from the block is also effecting the heat on the carbs. Which, by the way, seem to run better when they are a little warm, then when they are cold. If you are worried about a little warm air on your legs, it's probably because you are riding in flip flops and shorts
Easter
#24
Post by Easter »
CYBORG wrote:I think more is gained by the air blowing across the engine block. The heat from the block is also effecting the heat on the carbs. Which, by the way, seem to run better when they are a little warm, then when they are cold. If you are worried about a little warm air on your legs, it's probably because you are riding in flip flops and shorts
+1
when I built Dragon Wing several years ago, all the parts were in boxes and I had no clue what most of them were for. I did not make a conscious decision to leave off the heat shield, just didn't recognize it belongs. Dragon Wing is my most ridden bike and since then after wrestling the carbs off several (I think I have about 8 or more of the shields if anyone needs one) I haven't seen the need to reinstall them. I never pulled the engine from my '83 Aspencade so I didn't mess with the heat shield on it. That is the only bike I have ever noticed being uncomfortable from the heat on my legs.
Besides I only build Hot Rods--no pun intended. dancr
desertrefugee
#25
Post by desertrefugee »
I used to build hot rods. (Robin still does.) Not GLs.
zipster
#26
Post by zipster »
This is temp relevant, so I'll repeat it here....
So my GL1000 has been running on the hot side of normal range throughout the summer, enough so that I've bought a used set of air deflectors to mount. But the other day, running around town in 80 degree heat, when I shut it down I heard what can best be described as boiling noises coming from the engine/radiator. Fairly loud. Anti-freeze levels appear normal, although the reservoir was empty. Any advice? I've got a thermostat on order, and I'll try running observing coolant flow in the radiator this weekend. Any other thoughts or methods to eliminate the source?
Cheers,
-zipster
1977 GL1000
1975 Yamaha RD350
1978 Vespa P200e
1986 Honda Helix
desertrefugee
#27
Last week, I did head gaskets for a friend who'd overheated his "new" '77 GL1000. A nice original red specimen, he's had it for a couple of months and bought it for a song. His gauges were all non-functional due to the regulator being fried. I warned him that whatever led to the "event" needed to be resolved or he'd blow it again.
So, did the regulator work-around so he'd have gauges and took a short shakedown run. While it didn't overheat, it did push quite a bit of coolant out the overflow. Everything seemed to be in order, but we pulled the thermostat to test it. Well, it didn't need to be tested. It was bad. Not quite sure how it got like this, but that's how it came out of the bike. I've never seen anything like it!
desertrefugee
#28
...by the way. He also had one of those fancy chrome radiator grills. His temps were still running a little warmer than he liked, so he pulled that grill and saw a noticeable decrease in operating temperature. In Arizona, that's always a good thing.
mcgovern61
#29
Post by mcgovern61 »
desertrefugee wrote:...by the way. He also had one of those fancy chrome radiator grills. His temps were still running a little warmer than he liked, so he pulled that grill and saw a noticeable decrease in operating temperature. In Arizona, that's always a good thing.
I had one of those fancy chrome radiator grills on my '82. It ran pretty darn warm. Read elsewhere that they restrict airflow when used with the OEM radiator wings. Removed the grill and put an OEM rock guard back on. Lowered the temp quite a bit!
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
#30
desertrefugee wrote:Last week, I did head gaskets for a friend who'd overheated his "new" '77 GL1000. A nice original red specimen, he's had it for a couple of months and bought it for a song. His gauges were all non-functional due to the regulator being fried. I warned him that whatever led to the "event" needed to be resolved or he'd blow it again.
The first '82 I bought had a thermostat that looked exactly like that. Upon closer inspection, I could see plier marks on the shaft. It had been purposely bent to stay open. The cooling fan also had been hot-wired, and the water pump weep hole was plugged. Of course, the water pump was bad, and someone 'fixed' it... and I had no clue what I was buying...
