temperature and radiator wings
- zipster
Hi all,
Just wondering who is running the radiator wings and how much affect on temperature? I just ran a 1000 mile trip without them, and bought a pair for my naked Wing as it seemed to run a bit hot at highway speeds. I see a lot of naked Wings pictured without them.
Cheers,
Ray
Cheers,
Ray
~Don't skin yer knuckles whatever you do.
1977 GL1000
1986 BMW K100RS flying brick
1975 Yamaha RD350
1978 Vespa P200e
1979 Lambretta Jet200
1986 Honda Helix
1977 GL1000
1975 Yamaha RD350
1978 Vespa P200e
1986 Honda Helix
Re: temperature and radiator wings
I use them as that is how it came from the factory, obviously Honda deemed them necessary, so I use them.
one of the advantages of a temperature controlled fan, is it will turn on when needed. I have not run without the wings because I like the look. I do recall that when I added the steel "Harley-type" front fender it appeared to me the temp gauge was a little higher.
- Sagebrush
As long as you stay in Michigan you won't need them. Just don't take a trip to the southwest in July or August. Of course it won't just be the engine getting hot.
there is a reason we call it the dog days of August!
I would not run the old copper GL radiator without the wings here in Arizona. They make a big difference while underway. The Valk I have employs a dual core aluminum radiator. No wings. It works very well. If (when) I ever need a radiator for my '78, I'll be looking for aluminum alternatives to the OEM design.
Just to emphasize the point, today I just spent a warm morning helping a buddy pull the heads on his '77. Blown head gasket. Ran hot on the freeway.
Arizona Summer is rough on cooling systems. Especially 40 year old ones. Install the wings.
The wings are effective. If not running wings, when cruising at 50 on a hot day, put your feet up and direct air into the radiator. You will see the temp drop a bit.
- zipster
Thanks all, I'm putting the wings on. I'll probably descale my radiator also, just because. Blowing a head gasket on a long trip would suck.
1977 GL1000
1975 Yamaha RD350
1978 Vespa P200e
1986 Honda Helix
1977 GL1000
1975 Yamaha RD350
1978 Vespa P200e
1986 Honda Helix
having done that, you are right.... the cost of the U-Haul was not fun
Built several early wings now and most of the air wings that came with the bikes were pretty shabby so I left them off the final build, none of the bikes have had heating problems and I live in San Antonio where the summer time temps are 90 and above (far above) the only bike that has shown a sensitivity to the heat was an Aspencade with full dress AND WINGs. Turns out it needed a temp sensor for the fan. If I were working with a nice clean restoration I would leave them on.
I can assure you that sustained high speed running in elevated temperatures without the wings in place will result in higher engine temperatures. I cannot quantify that with real numbers, but only what I've observed on the factory gauge on my '78. I experimented with them off the bike for a while. It definitely runs hotter on open stretches of road. The lower the speed, the less it seems to matter. City traffic, no difference. I put them back on and immediately noted a difference.
I also had an '84 Aspencade with a fancy chrome grill goo-gah that seemed to run hotter than it should have. After trying a few things, a buddy suggested pulling that fancy grill. Sure enough, it dropped one or two digital gauge segments while underway.
The point here is that the small surface area of the radiator and it's narrow two-row copper construction does not make for the most efficient heat exchanger. Honda engineers felt those wings were necessary and I'm not going to second guess them. Especially in Arizona.
one thing to remember about air flow is that speed creates what is similar to a bow wave on a ship. the faster we go the more there is a bubble of air being pushed ahead and to the sides. wings would have little effect at low speeds, but as we speed up they are an attempt to funnel air into the radiator. I have always had wings on my wings, and I do not recall the fan needing to come on at speed and I have driven in heat a lot. As I mentioned earlier, the bigger HD type front fender seemed to cause an increase in the temp gauge when I put it on (in '79). This would make sense as the larger profile would affect the amount of air-flow to the radiator.
While not designed to accomplish this, having the gold wing heads sticking out each side helps cool the engine as well.
- zipster
Always wondered why they don't have fins on the GL1000 heads. Free passive cooling is hard to beat.
1977 GL1000
1975 Yamaha RD350
1978 Vespa P200e
1986 Honda Helix
1977 GL1000
1975 Yamaha RD350
1978 Vespa P200e
1986 Honda Helix
- mcgovern61
On my '82, right after restoration I ran without the wings because I did not know they were original to the bike (they were rusted away after sitting outside for 12 years). The bike would always run warm to hot on the temp gauge (upper third of gauge) even at highway speeds. Some 1100 experts explained the wings were OEM. I got a set off Ebay and installed. HUGE difference on the highway! The temp never goes above 1/2 on the gauge if running on the highway. As mentioned, not much difference at slower speeds (below 30 MPH). But above 30, you can watch the gauge drop as the bike is at speed for a few minutes.
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
they are miserable to clean?zipster wrote:Always wondered why they don't have fins on the GL1000 heads. Free passive cooling is hard to beat.
- 6 Replies
- 561 Views
Last post by heraldhamster
- 8 Replies
- 259 Views
Last post by ericheath
- 1 Replies
- 168 Views
Last post by Whiskerfish
- 10 Replies
- 344 Views
Last post by Pony Ruiz
- 15 Replies
- 356 Views
Last post by desertrefugee
