Very stuck slide bolts (pic)
- Unlimited
- Tin Member
Both front calipers' slide bolts that connect caliper to trac are stuck in their sleeves/collars. I'm trying evapo rust... But so far no luck...How do I get this out?
- IMG_20170830_191055.jpg (76.14 KiB) Viewed 359 times
'85 Unlimited
Re: Very stuck slide bolts (pic)
I would suggest something more like PB Blaster. Some people have made their own mix using ATF and acetone, as well. If you have the means, you might try 'cooking' them as well. Heat does wonders. Just be very careful of the fumes.
- Unlimited
- Tin Member
heat the sleeve up.
- Unlimited
- Tin Member
hallelujah! heat finally worked! i found red loc-tite in there!!!
thanks!
thanks!
'85 Unlimited
Unlimited wrote:hallelujah! heat finally worked! i found red loc-tite in there!!!
thanks!
- salukispeed
Good to hear you got it. That is weird there was loctite in there. Double check the threads for issues and your good to go
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Unlimited
- Tin Member
Threads look ok.
I guess last person to do brake job put loctite on thread and it got smeared on the inside of the collars... Here's one for posterity and how this bike has been so far..
- IMG_20170901_121823.jpg (88.63 KiB) Viewed 273 times
- 1v4qd4.jpg (39.75 KiB) Viewed 273 times
'85 Unlimited
