setting the idle mixture
5speed
Post by 5speed »
I checked the "shop talk" forum and didn't see this topic covered.
I want to take another stab at syncing the carbs on my 76.
I have to check the points and timing yet but it dawned on me while I was planning my "attack" that I don't remember reading anywhere about doing this.
I set them as per Randakks dvd and it was running lean on a couple of cylinders. turned the pipes blue...
I've used a vacuum gauge to set the idle mixture on my camaro (holley 4 bbl).
How does one accomplish this on the gl1000?
Re: setting the idle mixture
Idle drop procedure is called for by the book for the late 78 and all 79 carbs but many of us use the same procedure on all 1000 carbs. I do it basically by the book but depending on the setup of the bike I will add an extra 1/2 or full turn out when complete https://www.ngwclub.com/forum/viewtopic ... 09#p453009
5speed
Post by 5speed »
Tks WF. I wasn't looking for "idle drop". :oops:
Do you mean synchronization of the carbs?
5speed
Post by 5speed »
ericheath wrote:Do you mean synchronization of the carbs?
No eric. Setting the idle mixture on them. I "bench set" them as per Randakks video but the bike is running lean.
I think your only control on that is the idle drop method, unless you have a Gunson Color Tuner or wideband. Like Whiskerfish mentioned, get them close to best idle, back them out a half turn for a little more fuel to be safe....???
jdvorchak
Post by jdvorchak »
Idle mixture only affects the combustible mixture when at idle. If your plugs show the mixture is lean no adjustment of the idle mixture screw is going to help. Well unless you never open the throttle. Main jet size and metering needle affect mixture while above about 1/4 throttle.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
Fuel level in the bowl play a little role here too? I haven't heard it said much here, but I thought I've read other sites where fuel level has a lot to do with mixture.
The idle mixture does affect a bit more than just closed throttle idle. Check this from Mikuni. Fig. 7 shows a little about throttle position operation. http://www.iwt.com.au/mikunicarb.htm
Also, idle drop procedure is the best way to adjust the mixture screws.
Nice link Robin!
