Valve stem oil seal
- odyssey
Valve stem oil seal
I'm looking at the procedure for replacing the valve stem oil seals without removing the head.
https://www.ngwclub.com/forum/viewtopic ... e+oil+seal
Would it be possible to do this without air pressure to keep the valves closed?
Past rides:
'72 Vespa Rally 180, Honda Elite 125, Suzuki TU 250, Yamaha XT 600, Suzuki DR 650, Nighthawk 750
Current: '76 GL1000
Current: '76 GL1000
Re: Valve stem oil seal
Install a length of rope in the spark plug hole and bring the piston up, holding the valves against the rope. Pull the springs, replace the seals
- odyssey
Great idea, thank you!
Past rides:
Current: '76 GL1000
Current: '76 GL1000
old school.....just don't forget to leave a tail of the rope out of the hole, so you can remove it when your done
- jdvorchak
+1 with Cyborg. It's been done that way for years.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- tlbranth
I did it without rope. I think I just put the piston at tdc to keep the valve from sliding down too far. I modified 2 HF spring compressors to get the arms the same. It was way easier than I thought it would be.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- odyssey
Sounds good. It didn't work with arms of different lengths?
Past rides:
Current: '76 GL1000
Current: '76 GL1000
- tlbranth
It's been a while but it seems like the compressor has to be modified - maybe only because I read that here on ngw. I'm pretty sure I have 2 of them. If I do, you could have one.odyssey wrote:Sounds good. It didn't work with arms of different lengths?
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- odyssey
Thank you, I bought one a few days ago. I was just wondering if I need to mess with it
Past rides:
Current: '76 GL1000
Current: '76 GL1000
- tlbranth
You might. I just bought 2 of them and made a long arm and a short arm version. Give it a try. If it doesn't work, buy another and customize.odyssey wrote:Thank you, I bought one a few days ago. I was just wondering if I need to mess with it
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- Tin Member
I guess that's providing you removed the timing belts and cams first so you can get at the valve springs and their locks?CYBORG wrote:Install a length of rope in the spark plug hole and bring the piston up, holding the valves against the rope. Pull the springs, replace the seals
Wrong. Belts do NOT have to be removed to do valve seals. Cams do NOT need to be removed
- odyssey
Terry, I ended up making a small modification to the tool to prevent the arms from expanding (picture below). I would make the hooks of this tool a bit more curved at the end and limit their movement outwards. And then I would charge more than the $10 that I paid for it .
For the next victims: in addition to compressing the spring, I had to push the tool towards the cylinder. I then used a magnet to remove the cotters (metal stick in my right hand in the picture). The seal came off easily after removing its inner spring using a pick. I ended up not inserting a rope and the valve did not move much downwards as I placed the cylinder at TDC. Putting it back together was, as expected, a bit of a pain. Pressing the spring helped gain enough room to insert the cotters.
- 20171008_144727(0).jpg (156.25 KiB) Viewed 664 times
Past rides:
Current: '76 GL1000
Current: '76 GL1000
- calif wingnut
https://www.harborfreight.com/universal ... 60335.html $13
Qi-ron and I modified a pair in 2011 drilling the rivet out and using a intake manifold bolt.
- IMG_1520.JPG (122.84 KiB) Viewed 635 times
- IMG_1521.JPG (75.61 KiB) Viewed 635 times
- 7 Replies
- 977 Views
Last post by tlbranth
- 3 Replies
- 296 Views
Last post by taunusrainer
- 4 Replies
- 357 Views
Last post by John Schmidt
- 4 Replies
- 140 Views
Last post by Wetduck
- 11 Replies
- 348 Views
Last post by Sidecar Bob
