I guess that's why I called it out as information That I re-posted. and as Cyborg said it usually works with the NPT adapter in the Kit. Just a bit of careful assembly required. I am guilty of using bothjdvorchak wrote:Some people have too much free time on their hands....
OOps!! Did I say that out loud?
Oil switch thread
- salukispeed
Re: Oil switch thread
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
This oil pressure switch, as designed, will alternate between an opened or closed ground path circuit.
Its only purpose is completing a ground connection, when there is inadequate oil pressure, to illuminate the oil pressure warning light.
Anyways, ForWhatItsWorth, unknowingly sealing the oil pressure switch pipe threads with Too Much Tape could possibly effectively insulate their pipe threads' ground path connection from each other between the pressure switch and the engine. That's an application where utilizing the appropriate pipe thread sealing compound (generally called pipe dope) is typically a best practice.
Done.
Done.
Cliff (74yrs )
- 13 Replies
- 1408 Views
Last post by Mojogameplay
