Page 2 of 2
Re: Oil switch thread
Posted: Sat Oct 14, 2017 1:20 pm
by salukispeed
jdvorchak wrote:Some people have too much free time on their hands....
OOps!! Did I say that out loud?
I guess that's why I called it out as information That I re-posted. and as Cyborg said it usually works with the NPT adapter in the Kit. Just a bit of careful assembly required. I am guilty of using both
Posted: Sat Oct 14, 2017 10:52 pm
by gltriker
This oil pressure switch, as designed, will alternate between an opened or closed ground path circuit.
Its only purpose is completing a ground connection, when there is inadequate oil pressure, to illuminate the oil pressure warning light.
Anyways, ForWhatItsWorth, unknowingly sealing the oil pressure switch pipe threads with Too Much Tape could possibly effectively insulate their pipe threads' ground path connection from each other between the pressure switch and the engine. That's an application where utilizing the appropriate pipe thread sealing compound (generally called pipe dope) is typically a best practice.
Done. tumb2
