Combining a 77 and 78 engine to make one.
Moderators: robin1731, CYBORG, Oldewing, Forum Moderators
Re: Combining a 77 and 78 engine to make one.
Post #16 by CYBORG » Wed Oct 18, 2017 9:44 pm
I/we do agree. I have been around wings a long time, and I was smart enough to learn from those who came before me. You WILL do what you want, and should. But finding a donor engine with a kick start would be the tried and true method to resolve this problem. Or install the 78 engine
elslimdiablo
Post #17 by elslimdiablo » Thu Oct 19, 2017 5:54 am
:) Thanks Delling3. I'm not measuring the crank bearing clearances to replace the bearings, I'm measuring to see where they are at. I have had the 77 apart before when it had a blown head gasket and low compression on #4. I measured them out then to basically check the health of the internals and they were fine then, that was about 10k miles ago. Having a ring fail on #2 is a complete bummer but I'm going to venture the guess the crank and rod bearings are still fine. The new block is the unknow right now and it will get pulled apart, cleaned, and be measured out in the same way. I'll also have to check the block markings to see if I can transfer bearing/ crank assemblies from one block to the other. I know the dimensions can change, but without checking, I wont know. I haven't opened up th 78 yet, so I'm not sure if it is any good. It was a free turning engine sitting on a shelf. We'll have to stay tuned for the next episode of " As The Goldwing Turns" to find out! :-D
1977 GL1000
1977 RD400
1975 CB360T(in the family since new and restored)
1961 T20 Tiger cub SL
1959 T20 Tiger cub S
03 Shadow Spirit 750
elslimdiablo
Post #18 by elslimdiablo » Thu Oct 19, 2017 6:09 am
Sorry guys, I'm not questioning anyones experience here, or I wouldn't have asked the question in the first place. I do appreciate all the replys and will update you when I get things rolling. If it comes to a 78 short block with the 77 top end, thats just what it will be. My heart is not set on having the kicker, just a cool trinket to have. Thanks guys!
1977 GL1000
1977 RD400
pierce
My Album: pierce
Post #19 by pierce » Thu Oct 19, 2017 7:47 am
I have used good cranks with matching rods and bearings as a unit. It is tirelessly difficult to find cob rod bearings. Not just matched, but any new ones within reason. If a crank is good. Best option is to keep everything matched. Even the Piston rods are marked for balance so should be swapped in pairs. Just use new rings.
If the kicker is important, as it is to me. You can convert the crank. I detail how to do it in my engine thread. Just will need to remove the end of the 77 and attach it to the 78. Then use rear case of the 77.
Like Robin said, mark the crank. It's literally half way between marks. Either way you are fine
1976 GL1000
1978 Gl1000
elslimdiablo
Post #20 by elslimdiablo » Thu Oct 19, 2017 9:11 am
Hey Pierce, I went to your 40 build. Is that all I really need to do to convert a late crank to an early crank for the kick start gear? So if I am seeing this right, I should be able to remove those parts from my 77 crank and bolt them to the 78 crank? Please correct me if I'm wrong! Seems too easy- I never get that kind of luck, that's why I questioned it!
1977 GL1000
1977 RD400
pierce
My Album: pierce
Post #21 by pierce » Thu Oct 19, 2017 1:52 pm
It really is that easy!
1976 GL1000
1978 Gl1000
elslimdiablo
Post #22 by elslimdiablo » Thu Oct 19, 2017 1:55 pm
Well that will save me a lot of time! Thanks
1977 GL1000
1977 RD400
Post #23 by Whiskerfish » Thu Oct 19, 2017 7:42 pm
Got to agree with pretty much what has been said. Keep as many of the rotating parts the same with the same cases if you can. Remarking the crank is simple and the older cases did have some changes for the better. I am currently running a 77 engine with 78 carbs and that took me a couple weeks to get the tune right when I first set it up. I had to split the 77 block to investigate a small score in one of the jugs but everything stayed in the same short block. Just a lot easier and more economical.
elslimdiablo
Post #24 by elslimdiablo » Thu Oct 19, 2017 8:02 pm
From looking at Pierces' build, it looks like I wont have to do much to the 78 bottom end other than just a check over and a few updates (1200 tensioner, dampener plate removal).
1977 GL1000
1977 RD400
elslimdiablo
Post #25 by elslimdiablo » Sun Oct 22, 2017 7:29 pm
I busted my butt all weekend taking care of the yard and finally this evening I managed to take the heads off of one of the later engines. The pistons and cylinder walls look stellar, no ridge and still shows cross hatching. New question, are these head bolts look normal? I dont remember the 77 head bolts having machined groves cut in them.
1977 GL1000
1977 RD400
Post #26 by CYBORG » Sun Oct 22, 2017 7:40 pm
not sure what engine they came from, but I have several like that. Came from, what I believe, was a stock engine, not previously dismantled.
elslimdiablo
Post #27 by elslimdiablo » Sun Oct 22, 2017 9:13 pm
They came off of the 78' engine
1977 GL1000
1977 RD400
wingrider
Post #28 by wingrider » Sun Oct 22, 2017 11:38 pm
I’ve had the same bolts...can’t recall if it was on my 77 or the 84...but at least one of them had those bolts in it.
Post #29 by robin1731 » Mon Oct 23, 2017 6:02 am
All the heads I've taken off had those head bolts. One thing I do see "wrong" though. Not a good idea to set the head down on a bench with the cams installed. It is possible to bend the valves like that.
1975 GL1000 parts bike (parts for sale)
Oldewing
Secretary
Secretary
Post #30 by Oldewing » Mon Oct 23, 2017 6:39 am
Nice catch on the valve on the bench Robin, bet your not much fun on a "seek and find" puzzle.... lolol lolol lolol
82 GL1100 Interstate-Oldewing (under going MAJOR work, fresh frame, NEW motor)
68 CB 350 Wifeys and oh so cool
06 GL1800 Comfort and Nav-Farkels(RAT rode it, and came back, THIS thing has too many Farkels)
This ain't no ordinary run of the mill motorsickle club!! action1 gltriker 2015
Who is online
Users browsing this forum: SnoBrdr and 1 guest
