change a timing belt on a gl1000
- Rusty Probie
- My Album: http://ngwclub.com/gallery/my_album
Does anyone have a write-up on changing the timing belt?
Re: change a timing belt on a gl1000
the shop manual has a good one
- tlbranth
I found the timing part of this discussion thoroughly confusing. The last time I put the belts on, I referred to a single page in the shop manual and had no difficulty.Whiskerfish wrote:https://www.ngwclub.com/forum/viewtopic ... 447#p26447
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
so, I just make sure both pullys had the little arrow at the "Mark" When I put the new belts on, I make sure both pullys are at the mark... and I do not move anything else in the mean time
One cam will try to move due to the valve spring. Just hold the cam where you want it with a wrench. Make sure all pullies are at the marks before you turn the motor. I've seen a pro mess this up because he did it so many times he lost focus. check the bearings on the belt tensioners, if they sound like an old roller skate replace or rebuild them. When I'm done I turn the crank one full turn and re tension the left side again so they both are tensioned with a cam lobe on a spring. I loosen the radiator and swing the bottom out a little. Use the part number here and get Gates Belts at Napa or Rock Auto.
- 6 Replies
- 384 Views
Last post by Explorer
- 17 Replies
- 502 Views
Last post by Gowing
- 16 Replies
- 488 Views
Last post by desertrefugee
- 226 Views
Last post by Whiskerfish
- 4 Replies
- 386 Views
Last post by mrtwowheel
