Just finishing up testing of a totally new wiring system on my GL1000. all 4 turn signals are led and so are the dash indicators. I bought a 2-pin flasher many moons ago from NAPA. I've incorporated an emergency 4-way emergency flash setup and when I turned it on, the lamps just sort of varied in brightness. They didn't really flash too much. The dash indicators barely changed brightness. I unplugged the flasher and tested the light circuit by jumping the 2 leads that were plugged into it and got great results. Plugged the leads back into the flasher and now it doesn't work at all. One of the terminals has come adrift which is probably what's wrong. I'll buy another flasher but don't want the same bad results. I want a decent flash. Reading some of the stuff on the forum I saw there are 2-pin flashers with a ground wire which sounds like maybe that's the way to go.
So....any first-hand experience? Got one with definite on/off flashing? Nope, don't want shunt resistors. Just want a working electronic flasher.
electronic flasher
- tlbranth
electronic flasher
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
Re: electronic flasher
You obviously need a LED capable flasher.tlbranth wrote:Just finishing up testing of a totally new wiring system on my GL1000. all 4 turn signals are led and so are the dash indicators. I bought a 2-pin flasher many moons ago from NAPA. I've incorporated an emergency 4-way emergency flash setup and when I turned it on, the lamps just sort of varied in brightness. They didn't really flash too much. The dash indicators barely changed brightness. I unplugged the flasher and tested the light circuit by jumping the 2 leads that were plugged into it and got great results. Plugged the leads back into the flasher and now it doesn't work at all. One of the terminals has come adrift which is probably what's wrong. I'll buy another flasher but don't want the same bad results. I want a decent flash. Reading some of the stuff on the forum I saw there are 2-pin flashers with a ground wire which sounds like maybe that's the way to go.
There's one being sold on Amazon that is two prongs with a ground wire.
I have been told that works but have not used one myself as I gave up on using the LEDs because I could never get them to work.
78 GL1000 Original Owner 131k
I had all kind of problems with led rear lights, and filament fronts. I bought two adjustable led flashers off ebay for 4.95. They work for me.
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
What's adjustable? the voltage?Wangthang wrote:I had all kind of problems with led rear lights, and filament fronts. I bought two adjustable led flashers off ebay for 4.95. They work for me.
I had success with an led specific flasher from ebay for about 5 bucks
Not all flashers are the same. Even electronic ones. I've had to try different ones a times to get them to flash. Even from one bike to another the same one did not always work.
- desertrefugee
There are units available compatible with both LED and filaments - or a mixture of the two. Those might be your best bet.
Voo doo
1977 Gl 1000
1976 F1 750 SS
2007 Road King
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
- 4 Replies
- 318 Views
Last post by Bearpaw
- 3 Replies
- 313 Views
Last post by Casper
- 9 Replies
- 4976 Views
Last post by Sidecar Bob
- 12 Replies
- 508 Views
Last post by todd54219
- 6 Replies
- 692 Views
