Vetter headlight ring
Hi all- how does the headlight ring remove on the vetter fairings? also looks like the headlight might be either led or halogen; looks to have a post in the center...are led and halogen more or less power hungry than stock? thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
Re: Vetter headlight ring
the ring twists clockwise approx an inch or so.
Not sure what the current draw would be for a halogen but LED lights are significantly easier on the charging system..
there is a tab on the underside to loosen the lock before you turn it... it can be a PITA to get it off if it has been a long time
oops..forgot about that.rcmatt007 wrote:there is a tab on the underside to loosen the lock before you turn it... it can be a PITA to get it off if it has been a long time
LED should look like a small tower in the middle. The elements that illuminate are on the side of that tower. Halogen will have a glass bulb with the gas inside. LED is a lot less power draw but if Halogen it is probably similar to stock. They come in different wattages.
These are halogen Most LEDs look something like this
