1976 GL1 is farting :)
Thomas44
Post by Thomas44 »
Hi,
Can someone tell me what causes this "pops" ?
https://www.youtube.com/watch?v=_7hW3WgtFDc
I know that cylinder n°2 don't fire as it should because its exhaust pipe is 50% colder than the others (I use an infrared thermometer gun to see that).
Could it be a bad timing (only did a static timing) ?
Thanks for the help.
1976 GL 1000 Jaune sulfure.
Re: 1976 GL1 is farting :)
Did it just start this? Start after you did something? Have you had the carbs off? Have the carbs been synced? Have you done anything to fix it?
Could be a few things but other questions need answered first. ;)
Thomas44
Post by Thomas44 »
Carbs should be OK (cleaned, new seals, float ball level checked ...).
They are roughly synced ...
Coils, wires, plugs and spark plugs are OK.
Compressions are OK.
The problem started after new breaker points installation and static timing procedure.
I rode the bike today and it runs OK (good acceleration, speed ...).
I guess it could be even better but I have no point of comparison.
Maybe I'll tweek "the split the difference" stuff more.
I hope I don't have a tooth off on the belts ...
scootsx2
Post by scootsx2 »
If it indeed started after installing new points then I would revisit that procedure in detail and make sure it's spot on.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Miss at idle could be quite a few things. Everything from a weak battery up to mechanical issues in the engine. But yes if it just started then revisit the last thing done first.
raiddrten
Post by raiddrten »
I hesitate to come in here as a newbie, but i really like to just use a timing light as a spark checker. The timing light can spot a weak spark event. occasional missing spark events, or a no spark condition. It does this with the wires hooked up and the bike under compression, so that is under real world conditions. In short, you can see more with the light than you can hear with your ears. Then you can usually answer the question, "Is it the spark timing or is it the carbs?" "Do i have a bad wire connection on one wire or is it something else?"
I do not even use my [Harbor Freight ] timing light for its intended purpose as I do not trust the loosey goosey timing advance feature.
I can tell you that a timing light helped us through a 'comes and goes" condition with a pulse generator on a V-4 Honda that had a very good outcome. it saved us guessing the cause and hanging expensive parts on the bike.
Thomas44
Post by Thomas44 »
I'm quite sure the problem doesn't come from the #2 carb.
I already switched wire #2 and #1 to check if the problem comes from the wire/plug/spark plug and cylinder #1 kept on running OK.
I have a cheap strob light that I was supposed to use for the dynamic timing (obviously).
I try to use it with no luck because, let's be honest, you can't see in the "view" hole.
If I have to use it , I'll make a mark for F 1 and F 2 on the cam pulley.
I guess my best bet is timing.
What bothers me is that I have almost 6 to 7 degrees to divide.
Right now on cylinders #1 and #2, I Have one cylinder 2 degrees after -F 1- and the other one 4 degrees before.
On cylinders #3 an #4, I have one 3 degrees before -F 2- and the other one 3 degrees after.
Thanks for the input anyway.
To be continued ...
from your post#3
quote " Carbs should be OK (cleaned, new seals, float ball level checked ...).
They are roughly synced ... "
How close to correctly idle synchronized would that be? ......Bench synched, only? :-?
Cliff (74yrs ;) )
gltriker wrote:from your post#3
Yeah, I'm waiting on that to be set correctly and the points before we can really make any guesses. ;)
Lot's of guys have had carbs that "should" have been ok that were not close
Ok tumb2
Cliff (74yrs ;) )
Thomas44
Post by Thomas44 »
gltriker wrote:How close to correctly idle synchronized would that be? ......Bench synched, only? :-?
Checked with an homemade carb synchronizer :mrgreen:
Thomas44
Post by Thomas44 »
It had something to do with the timing.
https://www.youtube.com/watch?v=XfnlAq8T5Cw
You still can hear some light detonations in the left muffler but way quieter than before.
The weather forbid any road test but It should be OK.
Cylinder #2 is now slightly hotter than the others (maybe a little too lean ?)
LuckyEddie
Post by LuckyEddie »
Remove the points cover and make sure the wire connection to the points is not grounded against (or even close) to the housing. That will interrupt the spark, build up unburned fuel and occasionally one will get through and touch off the load (popping).
There is no such thing as close when synchronizing carbs.
Good luck.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
Don R
Post by Don R »
I'd be willing to bet it's a lean pilot jet. Timing will make it better or worse.
Don R wrote:I'd be willing to bet it's a lean pilot jet. Timing will make it better or worse.
If that is the case it is just masking the problem, not fixing it.
Reading this, "The problem started after new breaker points installation and static timing procedure." it points to the points/ignition. As always, if you develop a new problem always go back to the last thing you did.
