Coolant leak found
Coolant leak found
One of my first post was, where did all the rust around #2 plug come from. I think I found the culprit. There is silicon under the water pipes, with two different bolts. When I do the timing belts, and water pump I will pull off the plumbing and paint, and polish. Does anyone know where I can find the o rings and gaskets for the plumbing?
- 20180126_120024.jpg (80.06 KiB) Viewed 135 times
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
Re: Coolant leak found
There is a member here who sells a ' kit ' that contains the o-rings and elbow to head gaskets on eBay for less than $10. Unfortunately, I can't seem to find the link at the moment... someone will chime in...
You can still get them from Honda.
Backyardbob sells them on fleabay. Username there is huntech2006 https://www.ebay.com/itm/Coolant-tube-g ... 6016.l4276
If you fuss with those be very cautious about the ORings. they are a press fit and can be messed up very easy
Ehadams, member here, has slightly oversized orings. I’ve usually just made the gaskets from a cornflakes box material, but the 1200’s, which fit other years, have a copper or steel gasket which is nice. A little permatex ( not silicone or the like) and they’re reusable.
Check the threads under the longer bolt.
- 1 Replies
- 162 Views
Last post by Whiskerfish
- 20 Replies
- 872 Views
Last post by 77Gowing
- 8 Replies
- 362 Views
Last post by scootsx2
- 27 Replies
- 1366 Views
Last post by sickradsean
- 4 Replies
- 191 Views
Last post by NCScooter
