GL1000- how to adjust furl level shown on gauge
Hi all - after tank cleaning the gauge reads low; how is this adjusted? hopefully not by that little screw by the fuel rod thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
- flyin900
Re: GL1000- how to adjust furl level shown on gauge
There is an internal adjustment inside the rectangular metal box where the float arm is attached. It is covered in the FSM and even after the adjustment on these old gals it still isn't accurate by any means. I have played with both the GL1000 and GL1100 adjustments and never got anything that was satisfactory overall.You can improve it somewhat, yet I always use the trip meter reset to zero after I fill up as a more accurate gauge of my fuel level and range.
If your readings have changed from before you cleaned the tank then you may have bent something on the fuel rod assembly, as you should be getting a full reading when the tank is full, or you have deflected the float assembly to the top of its motion if the gauge is still out of the tank. The accuracy is diminished once the level start to drop below a certain level. Mine is usually showing towards the empty area on the gauge when there is still at least 1\3+ of gas still in the tank.
Current Bikes:
- RB
Bent the arm on the device in the tank until you're are happy. PS you can do it with the unit our of the tank..just hook up the wires, turn the bike on and move the arm to see how it reads. If you drop it to the bottom position it should show on or close to E = turn your reserve on..more accurate to run the tank empty add one gallon and put the unit in and see where it reads adjust arm to show just above E..
Ps bike on flat level surface...garage floor and the bike straight up like you were riding it..not on center stand..that tilts it a bit forward...but really not that much depends how accurate you want it.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
I have adjusted a couple. there are specific values to set with an ohm meter in the book. Once you remove the sending unit you remove the tin cover and adjust the small slider on the rheostat. pretty easy really and worked out well for me.
- tlbranth
A few years back, a member posted "fuel gauge is for amusement only". Seemed to agree with my observation. When I restored the bike I chucked the gauge. Like Flying900, I use the trip meter.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- 77Gowing
I've looked in the book and never seen any procedure for adjusting the sending unit, so obviously I missed it some where.Whiskerfish wrote:I have adjusted a couple. there are specific values to set with an ohm meter in the book. Once you remove the sending unit you remove the tin cover and adjust the small slider on the rheostat. pretty easy really and worked out well for me.
Please WF provide the name of the book and the page numbers.
Thanks in Advance
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
- BikeMaine
Wow, I'm extremely lucky, my gauge reads really well.
(Now that I've said this, the darn thing will most likely never work again...)
Kevin
1982 GL1100A
1982 GL1100A
- 11 Replies
- 492 Views
Last post by Chainman
- 1 Replies
- 317 Views
Last post by gltriker
- 11 Replies
- 250 Views
Last post by Whiskerfish
- 15 Replies
- 730 Views
Last post by KYpondman
- 18 Replies
- 2257 Views
Last post by flyin900
