How to mount rear turn signals
- Zinc Member
Greetings! After several months without a NGL I'm now tinkering with a 1977 model. The previous owner had the rear turn signals mounted to an after market luggage rack and I'm attempting to put them back to stock. I think I have all the parts, but can't seem to figure out how to mount them. Any tips? Pictures?
Thanks in advance.
Thanks in advance.
1980 GL1100 (Sold)
1977 GL1000 (Sold)
1977 GL1000 (Sold)
Re: How to mount rear turn signals
My 76 had them mounted on the grab rail.
yea 75-77 have them mounted to the grab rail. 78 moved them down to the brake light assembly.
- delling3
I removed the grab rail from my '76 build. Fabricated some brackets from 3/16" aluminum which mounted in place of the helmet locks. I mounted the turn signals to those brackets.
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
and what a poor job they did..Whiskerfish wrote:yea 75-77 have them mounted to the grab rail. 78 moved them down to the brake light assembly.
I disagree.5speed wrote:and what a poor job they did..Whiskerfish wrote:yea 75-77 have them mounted to the grab rail. 78 moved them down to the brake light assembly.
78 GL1000 Original Owner 131k
mine looks like a 12 year old did it..SnoBrdr wrote:I disagree.5speed wrote:and what a poor job they did..Whiskerfish wrote:yea 75-77 have them mounted to the grab rail. 78 moved them down to the brake light assembly.
- flyin900
If you don't have the grab rail and can't locate one then Sirus Consolidated in Canada sells a reproduction chrome one at a reasonable cost for new.
Current Bikes:
- Zinc Member
Thanks! I got a new grab rail from David Silver Spares, but the mounting bolt on the turn signals is too large in diameter to fit through the hole in the grab rail. So, I may have incorrect turn signals. (Or was sent an incorrect grab rail). More to follow. Thanks again!
1980 GL1100 (Sold)
1977 GL1000 (Sold)
1977 GL1000 (Sold)
Are you sure you have rear turn signals and not front ones you are trying to mount? I had a box of parts with my project when I bought it and "no" lights installed on the bike. I finally figured out the front turn signals have two wires and the rears have one wire. On an extra set of rear lights I have, I found wires grounding the left rear and right rear light fixtures. I assumed because the lights are mounted in rubber on the grab bar, so I grounded the lights on mine as well.
2001 GL1800 Illusion Red
- Zinc Member
No, I'm not sure. These units have two wires, but it appears that the ground wire was installed at some point by the owner who installed the rear rack. Is it difficult to find stock rear turn signals? I do have the rear mounting stems.
1980 GL1100 (Sold)
1977 GL1000 (Sold)
1977 GL1000 (Sold)
- delling3
I have a pair from a '78 that are in great shape. The mounting studs are different, but are interchangeable if you have the mounting stems for the '77. Let me know if you are interested.
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
- flyin900
The fronts have a much larger mount so that maybe your problem. The fronts should be the two wire circuit as they have a dual filiment bulb consisting of the running light and turn signal filament. The rears are a single filament for the turn signal only.
You may have the wrong connector on there to adapt to the rear grab bar.
Current Bikes:
- Zinc Member
Still waiting on a couple of parts to try again on this.
In the meantime I was doing some odds and ends and found this taped to the underside of the door to the false tank. Amazingly good condition for 40 years-old!
- 77 Goldwing.jpeg (130.06 KiB) Viewed 216 times
1980 GL1100 (Sold)
1977 GL1000 (Sold)
1977 GL1000 (Sold)
- franchise2k
- Tin Member
You can always mount 78-79 rear signals. They are mounted on the taillight instead of the grab rail. (if your rail is missing)
1976 GL1000 Cafe
1976 GL1000 Vintage Cruiser
1951 Ariel Square Four Mk I
- 1 Replies
- 154 Views
Last post by Paul Narramore
- 25 Replies
- 588 Views
Last post by 82aspy
- 205 Views
Last post by SnoBrdr
