I am in the process of taking the heads off, and the bolt on the cam pulley is tight!
Are there any tips on securing the pulley while loosening the bolt?
I don't want to tear anything up, which sometimes I seem to have the ability to do...
Thanks again
Mike
Cam Pulley Removal
Cam Pulley Removal
Mike
Bakersfield
78 GL1000 Current Bike
2004 R1150R Sold
2000 Sportster Sold
1994 FXR Sold (should have kept)
84 1200 Aspencade Sold
80 1100 Standard (should have kept)
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
- flyin900
Re: Cam Pulley Removal
The torque on that bolt isn't too much, so if you have the head off and no opportunity to loosen the bolts while the heads are still on the motor then I would use a rubber strap wrench. The type designed to hold oil filters etc; I use this style quite often to hold a variety of round objects that need to have centre bolts removed. Ideal for your issue or clutch housings, or alternator rotors etc.
Current Bikes:
Or just use the old belt...flyin900 wrote:The torque on that bolt isn't too much, so if you have the head off and no opportunity to loosen the bolts while the heads are still on the motor then I would use a rubber strap wrench. The type designed to hold oil filters etc; I use this style quite often to hold a variety of round objects that need to have centre bolts removed. Ideal for your issue or clutch housings, or alternator rotors etc.
You can also put a bolt in the holes for the belt cover. Belt would be safest in case the belt cover bolt breaks off in the head, however I have done it many times that way.
Got a strap wrench at HB, worked great!
Thanks
Thanks
Mike
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
- 7 Replies
- 365 Views
Last post by Goboy
- 12 Replies
- 426 Views
Last post by ericheath
- 1 Replies
- 322 Views
Last post by Whiskerfish
- 3 Replies
- 144 Views
