Stripped float bowl screw holes
I am rebuilding a set of GL1000 carbs and have several screws holes stripped. The original screws are M 4X0.7. My question is can I drill and tap and go to a 4.5X0.75 screw?
Thanks Dannie
Thanks Dannie
79 GL1000,75 GL1000,76 GL1000 LTD,70 CB750k JDM, 79 CBX, 2000 Valkyrie CT 2008 Goldwing Roadsmith
Trike and another 76 LTD bad shape, and several more for parts.
Re: Stripped float bowl screw holes
Fix them right. Use the correct size time-cert. Never have to worry about them again. That's how I fix all the carbs that come in here.
Thanks robin, This is the holes I am having trouble with. Looks like in this hole the screw bottoms out before it gets tight on the bowl.
If it bottoms out someone put a screw that was longer than stock in there. Easy to change that.
- tlbranth
Robin - I've used helicoil before but not time-sert. You think they work better? Easier to use maybe?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- odyssey
From Mike Nixon:
http://www.motorcycleproject.com/text/c ... epair.html
Past rides:
'72 Vespa Rally 180, Honda Elite 125, Suzuki TU 250, Yamaha XT 600, Suzuki DR 650, Nighthawk 750
Current: '76 GL1000
Current: '76 GL1000
- Liam
For that job time serts are the way to go.
- Liam
This is what they look like after fitting
I use a lot of heli-coils for 6mm and larger. But the bowl screws being so small the time-cert is a better option IMO. The kit and inserts aren't cheap but they should hold up forever once installed.tlbranth wrote:Robin - I've used helicoil before but not time-sert. You think they work better? Easier to use maybe?
- Toehead
Agreed. I've never regretted buying the kit. Once you are done, the screws will be riding in a steel insert. You can take them out and put them in a hundred times and never have another problem.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- RB
OK, have to ask why is tapping to one size larger..such a bad idea..or even same size but coarse threads? or even moving to standard thread if it's less of a jump up in size.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
TRB wrote:OK, have to ask why is tapping to one size larger..such a bad idea..or even same size but coarse threads? or even moving to standard thread if it's less of a jump up in size.
hat's the first step to mechanic's trouble.
I agree
- RB
I could see that if one put in a sheet metal screw to fix it..which I have found on e some bikes I have purchased granted they were barn finds but still a screw metal screw!! But just a different size thread..shouldn't be that big of a deal if the spot has sufficient meat to handle it..maybe paint the head red so it's noticed the next time it comes out.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Some folks will always grab whatever is in arms reach to fix a problem. And others will seek out the proper part. Now I know not everyone has the proper stuff available in their town. But the internet is usually pretty close, as well as UPS. Proper planning makes the job go easier, and really helps the new owner when you pass it on. I have seen a lot of parts that have been "mickey moussed" together, and repairs became very dis heartening . I take pride in my work, and always try to do it right the first time.
- RB
I guess I am questioning why tapping out a bit is a bad thing(mechanically) if there is enough meat to handle the larger thread. The only down side I see is having a different thread size which if when reinstalling years later you mix up the bolts and trash the wrong threads if you are a gorilla and not paying attention..which is a concern. Of course trying to put a larger thread in usually won't even start!
Not saying you guys are wrong just wondering how big a deal it is.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
