valve spring compressor
mmrabit
Post by mmrabit »
I bought a valve spring compressor at HF, the kind you can use with the heads on the motor (seemed like the only kind they had), but it doesn't seem to work. The hooks slip off the springs, like they are not engaging far enough.
I have C-Clamp that maybe would work?
Put an open end wrench on the valve spring end so you can get the keepers out and the other side on the head of the valve, does that sound feasible? Or would I risk messing up my valves or head? The heads are off the bike for head gasket replacement along with cam and valve stem seals.
Seemed so simple....
Once again any advice is appreciated
Mike
Mike
Bakersfield
78 GL1000 Current Bike
2004 R1150R Sold
2000 Sportster Sold
1994 FXR Sold (should have kept)
84 1200 Aspencade Sold
80 1100 Standard (should have kept)
Re: valve spring compressor
A lot of us use a c-clamp but cut a notch in the pad. The adjustable wrench idea might work. My guess is it would have to fairly thick.
Steve81GL1100
Post by Steve81GL1100 »
You can rent one from your local CarQuest or Advance Auto Parts. Or Auto Zone, whatever you have locally. It's an automotive C-clamp style. I used it with great success on my 81. The usual arrangement is, you buy the tool but get all your money back when you bring it back.
Steve
Steve
1996 BMW R1100R
odyssey
Post by odyssey »
I used a C-clamp. Not easy but doable.
Past rides:
'72 Vespa Rally 180, Honda Elite 125, Suzuki TU 250, Yamaha XT 600, Suzuki DR 650, Nighthawk 750
Current: '76 GL1000
odyssey wrote:I used a C-clamp. Not easy but doable.
But he is doing it with the head off. The easiest way is the c-clamp style compressor. As stated earlier you can rent/buy them at nearly any auto parts store.
Wangthang
Post by Wangthang »
Every engine build shop I ever worked it was socket, and hammer. Worked for some really good people, Jim Headrick, Rossville, Ga. Was pretty slick.
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
I uses socket and hammer to remove.....but a spring compressor is needed to install
tlbranth
Post by tlbranth »
I bought 2 HF spring compressors and swapped arms to get 2 with equal length. I don't remember having too much trouble getting them to work. Anyhow, I have 2 of the things - one with long arms one with short. I'll part with one if someone has a need.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Andersd
Post by Andersd »
Since I don’t have a valve compressor I made one up from a steel pipe and a C-clamp. Cut to about five cm and then a hole on the side to get the locking parts in and out. Ten minutes with the grinder.
//A
Gl1000 1975
Gl1100 1981 sidecar rig
odyssey
Post by odyssey »
Nice! I wonder if PVC would work.
Past rides:
Current: '76 GL1000
JSBail
Post by JSBail »
Andersd wrote:Since I don’t have a valve compressor I made one up from a steel pipe and a C-clamp. Cut to about five cm and then a hole on the side to get the locking parts in and out. Ten minutes with the grinder.
//A
I actually do have a couple of valve spring compressors including a large automotive c-clamp style one but neither would work on the valve springs on a cb550 I once had because the springs are more recessed into the head on a 550/500 than they are on a 750 or GL so I came up with short piece of steel pipe and slotted it like yours and used it with a regular c-clamp.
Scott
mmrabit
Post by mmrabit »
I ended up using my C clamp & a short piece of PVC pipe with a slot cut in it, worked great!
Never did get the HF valve spring compressor to work to my satisfaction.
Thanks again for the advice.
Mike
Mike
Bakersfield
2004 R1150R Sold
2000 Sportster Sold
