Electrical and Starter issue questions
- Johnnygoesnaked
Hi there!
I was hoping for some feedback. Now this is an issue that's more advanced than my skillset and I'd appreciate some input, however at the moment it's not urgent and more of something I'd like to get sorted.
On my GL1100 1981 interstate, I've had to replace the speedo with an earlier version.
The 81interstate speedo runs a few auxiliary functions power through it, such as the air pressure indicators.
The replacement speedo (older model) doesn't have that.
So then my headlight power stopped working. there's no power coming off the headlight plug at all, low or hi beam.
I've rewired my headlight straight to the fuse box on low beam, though it's not the best solution, I'd prefer to have the original electric set up working.
So the second issue that's come up since then is that the bike struggles to turn over when starting it intermittently. This never happens on a cold start, only after I've run the bike and in the heat of the middle of the day.
Looking at the wiring diagrams, I wonder if these two issues are related due to the black wire that feeds into the starter and rectifier. Also I can see that the power for the headlights do head through the speedo, though again, right now none of the original plug's wires read anything at the moment (I have a spare wired in currently).
any thoughts?
http://goldwingdocs.com/forum/download/ ... &mode=view
any thoughts?
GL1100 interstate 81, stock black, naked with panniers
Re: Electrical and Starter issue questions
Your issues may or may not be related. The starter is known to have issues when warm if it needs a good cleaning. They get really gunked up inside which causes poor performance. The starter button itself is also a weak point, mostly because the headlight circuit runs through it (the headlight cuts out when the starter button is depressed so the starter has full juice). There are numerous threads related to both issues.
BTW, I have a spare '81 speedo I could part with...
- Johnnygoesnaked
Thanks mate great advice! Mmm looks like I'd have to remove the engine to get to the started. Perhaps a winter project then.
About the speedo - I just bought another speedo, though it's not exactly the same one hence this issue - so I don't think it's the time to buy yet another. But perhaps down the road, thank you
The starter can be removed without removing the engine, even though the Clymers manual says otherwise. The bike needs to be on the side stand when reinstalling the starter. Lining up the starter shaft splines with the gear inside the case can be a bit of a challenge, but very doable. I've done it three or four times...
- Johnnygoesnaked
Right. Ok, good to know. Any words on how you do it as an addition to the clymers manual perhaps?
- 77Gowing
Shoptalk has a PDF downloadable Honda service manual.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
Removal is pretty straight forward. On the 1100, I don't think you have to remove or loosen the head pipe (on the 1000 you do), because I did mine when the exhaust was off anyway. Be careful when removing the cable. It is sandwiched between two nuts, so put wrenches on each so you don't twist the post. The internal wires on the post can be damaged fairly easily.
When you pull the starter apart, you will find bushings in the front and back. Keep them in order, as they are different thicknesses, and they need to go back the same way.
Here's a link to ShopTalk, which has a couple of good threads on the starter. The one about 1200 starters is pretty much the same as 1100's. Good luck!
page/ST
page/ST
I can't say for sure about other 'Wings but on my '83 with '79 engine I always had to remove the left crash bar so I could remove the header and then remove the gearshift pedal and the rearmost exhaust stud to get the starter motor out. I would be surprised if your '81 is much different.
BTW: I don't understand why people believe that the bike has to be on the side stand to put the starter motor back in. I've had starter motors out & back in a number of times on mine over the years, on the side stand, on the centre stand and with the sidecar attached (= bike sitting upright) and from my experience having it upright so you have more room to work more than offsets having to fiddle a bit more to get the splines on the motor's shaft into the ones in the sprocket.
- chewy999
I had the same issues when starting with a hot engine. No problem when cold, but on a run, after stopping for fuel I sometimes had to sit and wait for the engine to cool. Tried brand new starters with little difference, and eventually put it down to rectifier/black wire problems. If you read the threads below, that explains what I did try with much help from the guys here, but in the end, I bought a (genuine) CBR600 rectifier, and ride with the headlight on. Got to say, still not perfect, but far better than before. Using the CBR600 rectifier does away with the black wire.
https://www.ngwclub.com/forum/viewtopic.php?f=1&t=63268
https://www.ngwclub.com/forum/viewtopic.php?f=1&t=63432
https://www.ngwclub.com/forum/viewtopic.php?f=1&t=63587
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Oh yeah, I forgot:
1) When mine was hard to start when hot I cleaned the starter motor, and when that didn't help I installed a rebuild kitand when that didn't help I had one rebuilt by a shop and finally bought an aftermarket replacement. It turned out that the carb to plenum seals were leaking, which allowed fuel to pool in the plenum and when I shut the engine off it would run into one or more cylinders. Letting it sit for a while to cool down must have let the fuel evaporate enough that the starter could turn it fast enough to start (the oil never smelled of fuel).
2) Re headlight: The Start button has a second set of contacts that turn the headlight off while the starter motor is running so that the starter can have the battery's full output. It is pretty common for the contacts in the handlebar switch assemblies to become dirty over time so that they stop making good contact. You can often remedy this by spraying contact cleaner into the little hole in the housing below the offending switch/button and working the switch vigorously a few times. If that doesn't work you may need to disassemble the switch and clean the contacts with more contact cleaner and an old toothbrush.
Note 1: Use real contact cleaner, not WD40. WD leaves a sticky residue that will attract dirt and eventually mess up the contacts again.
Note 2: Never use sandpaper on switch contacts. Grit from it can become embedded in the copper and sither keep the contacts apart or scratch the mating contact. If contacts are pitted always use a very fine file to dress them (points files are best).
Maybe you've tried this already, but always a good idea to try jumper cables and a known good battery when the starter is slow. A marginal battery can sometimes fail to deliver the goods after a heat soak on a hot day, but work ok when things are cooler.
- 25 Replies
- 902 Views
Last post by tlbranth
- 6 Replies
- 247 Views
Last post by robin1731
- 8 Replies
- 310 Views
Last post by Track T 2411
- 8 Replies
- 1318 Views
Last post by heraldhamster
- 14 Replies
- 436 Views
Last post by jdvorchak
