white smoke
- Rusty Probie
white smoke
need some advice. just bought my first Honda Goldwing (first bike ever actually) picked her up for $200. 1980. she runs, but is missing a lot of stuff and isn't running right. my biggest problem right now that I'm struggling with, is that my left side exhaust is just blowing out white smoke that reeks of gasoline. I've got the carbs off, and I'm going to go through and clean them and POSSIBLY go ahead and do the rebuild. (the bike had been sitting for 2 years) but before i go and put it all back together is there any advice? anything i could be missing? i am by no means a mechanic. I'm a youtube mechanic at best so my knowledge on this all is very slim.
- RIP: cookie
Re: white smoke
Welcome to the 'Wingdom.
I'm not a mechanic but it sounds like a headgasket .... maybe a compression check before you run it much ?
Re: white smoke
Yea pull the plugs and see if any looked steam cleaned
- 77Gowing
Re: white smoke
Welcome, rat and WF know what they're talking about.
Good luck you'll get it sorted out.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
- Rusty Probie
Re: white smoke
1-10 on difficulty of doing head gaskets?
Re: white smoke
Replacing the head gaskets is a relatively easy job, probably a 6... if you can follow directions, and pay close attention to detail. You will need a torque wrench and a means to clean the old gasket material off the surfaces, as well as basic metric tools. Do a compression test before assuming that's your issue (Although it seems likely) just to be sure.
Re: white smoke
No real way to know, not knowing you. For me I'd say 1. But I've done several over the years. And to me if you have the heads off you don't just add new gaskets and O-rings. At a minimum you put in new valve seals. Check the valve spring pressures. Clean the valves and combustion chambers and intake/exhaust runners. Again those are all a 1, for me, on the difficulty scale.Huskerfanadam wrote:1-10 on difficulty of doing head gaskets?
But yeah, follow the directions in the manual. Have all the gaskets and O-rings you need before you start.
And, "don't forget about the small 6mm bolt at the bottom of the head".
- 466 Views
Last post by CYBORG
- 18 Replies
- 1194 Views
Last post by roncar
- 17 Replies
- 1171 Views
Last post by Lucien Harpress
- 57 Replies
- 3157 Views
Last post by Beetleman
- 11 Replies
- 1630 Views
Last post by Gowing
