Single solex conversion and oil leaks
I finally got the solex rebuilt and mounted and today I started it up and it seemed to run pretty good although not yet perfect. It ran good enough to tell me it's doable and my ignition system is close to being OK.
Now the problems. I have a very minor oil leak coming from the oil filter cover where it meets the front cover. I probably just need a new o ring there.
The real problem is a major oil leak coming from the little round hole on my fuel pump. I had the fuel pump completely unhooked (no fuel lines) and was running the engine off my gravity feed auxiliary fuel tank. There has got to be a way for the crankcase to ventilate blowby gasses but I see none.
Please chime in with any advice, comments, sarcasm, insults, or anything else that greens your bean.
Thanks. Dave
Thanks. Dave
Re: Single solex conversion and oil leaks
Adding your bike model in your signature will help people opine who may be able to answer you. Most gl’s vent the crank via a tube on the rear upper left of the motor. A tube carries it to s canister to separate water, oil, and excess gas blow by.
(looks like a '78/79). Fuel pump is not rebuildable. If the diaphragm is blown out, you'll need to source a used one or <gulp> NOS. Or go electric. Can't help you with the Solex.
I should have said it is a 79. So am I correct in assuming the only crankcase vent is the black hose that goes to the small canister in the last picture.?
Would a bad fuel pump make it squirt oil out the small hole in the first picture?
so I guess what I am asking is can I block the pump bracket off and use a 1200 pump?
I am looking at the 1200 fuel pumps on ebay. can someone suggest which one to get. they all look like 5\16 fuel connections but I can get around that OK
- lcallison
I found an electric pump rated at 2.5-3 lbs at O'Rielly's. I ran it on my 76 for several years.
Larry
84 GL1200A
79 GL1000
84 GL1200A
79 GL1000
I converted to a 1200 pump on my '78. I love it. Best mod I ever did to it. They're easily found on ebay, but prices vary pretty widely. You'd want the 1200 bracket, too. Based on Cyborg's recommendation, I modified a sacrificial pump housing.
Here was my project thread:
viewtopic.php?f=1&t=63520&hilit=electric+fuel+pump
That's part of it. There's a second hose that runs from the port on top of the engine case on the left side up to the airbox. Two hoses from the airbox, that one and the other that goes to the separator canister you mentioned.So am I correct in assuming the only crankcase vent is the black hose that goes to the small canister in the last picture.?
I am using a single solex so no original airbox.
Ha! (I knew that, but brain farted.). I think the canister should fall off if you don't have the air box. The hose from the crankcase port could just run to a small filter. But place it low. They can get a little messy.leggman wrote:I am using a single solex so no original airbox.
Did a compression test and have 95 Lbs. at all cylinders. That's weird because with the valve cover off I can feel air blowing out when it is running? After lunch I am going to remove the oil catch can and try it again. If I have to tear into the motor then the whole project might get cancelled.
Okay, I think I have my leaks stopped. Evidently when I took off the stock breather housing I removed the line that used to go from the engine up to the breather housing and hooked the engine breather straight into the catch can. That doesn't work, It lets crankcase pressures build up to the point where it will begin to leak oil everywhere.
I put the plugs back in after the compression test and unhooked the catch can and started it up and ran for several minutes and now have NO oil leaks. Woo Hoo. I should have known better because the crankcase pressures will build with no where to go. I am thinking of re attaching the catch can but drilling a hole in it near the top to let the pressure out.
Now I am moving on to ordering a 1200 fuel pump and trying to find a mount somewhere.
Compression test with WOT? If not you’re probably fine.
That crank case vent should not have any pressure behind it. While idling running you should be barely able to feel any pulses of air. It may increase slightly under a load but it should not be pushing oil out. When i changed mine around a couple years ago I used about a 4 inch section of hose and put a filter on the end and it lays on top of the engine and does not leak a drop.
- Lead Member
Be sure to check the oil in case the bad fuel pump was leaking fuel into the oil
I went out this morning to start it and it hydrolocked because I left the gas on all night. I pulled the plugs and spun it over to get the gas out. It starts but will not idle worth a crap. Turning the mixture and idle screws do not help. The single solex thing was just an attempt to make things simpler but I am starting to reconsider.
I had rebuilt the original carbs several years ago and had it running pretty good but then it sat for years in a shed and went to crap again.
I am seriously considering cleaning the original carbs and giving that another go.
I could still try the solex on my 75 that I bought last year because when I bought it it came with NO carbs at all. Got it cheap.
Oh by the way after I got the gas out of the cylinder today I drained the oil and there was no gas in the oil at all.
I am thinking about a project using the 79 engine and drivetrain because I have other bikes to ride. I will try too post a link below.
www.youtube.com/watch?v=3ll0KR3qAiQ&t=19s
- 7 Replies
- 576 Views
Last post by Whiskerfish
- 1 Replies
- 1475 Views
Last post by Wasabi
- 1 Replies
- 1051 Views
Last post by TNTbefree
- 7 Replies
- 3204 Views
Last post by mtwinger
- 1 Replies
- 1310 Views
Last post by digschopper
