Lately I've been getting some fluid weeping from the front master on my 81. Not a huge amount, just enough to notice wetness around it and the reservoir, and a few spatters on the lid of the right saddlebag. I'm running DOT 5 silicon fluid. Despite very mixed reviews on this, I am SO glad that's what I used or I would now be repainting the bag lid as well as fixing the master.
Anyway, I rebuilt the master in 2014 (10k miles ago) with a K&L kit from George Fix. Replaced hoses (OEM-style rubber), rebuilt calipers with K&L kits, everything top to bottom was new. Last winter, I replaced the upper front hose with a slightly longer one because I felt the first replacement was an inch too short. Also new EBC pads last winter. Otherwise I just ride it every day. So that's the back-story.
With the weeping, I have narrowed it down to 1) fluid pushing past the seal at the lever end of the master; and 2) fluid weeping past the O-ring seal on the reservoir where it snaps into the master. So I need to rebuild the whole mess again....
My questions surround the longevity of the initial rebuild, and also DOT 5 fluid. I've read where the silicon can cause seals to wear out prematurely, and what I'm experiencing certainly points to that.... However, the DOT 5 DID save my bacon by not eating the paint off the bag lid when it did leak.
So, some advice? Should I rebuild and stick with DOT 5 and expect another rebuild in 3-4 years? Or should I take the opportunity to go back to DOT 3 while I have it apart? Which raises another question.... If I do go to DOT 3, how do I deal with getting rid of all the DOT 5 in the hoses and calipers? Do I need to replace hoses and rebuild calipers again, or is there a reliable way to flush the DOT 5 out of there?
Anybody dealt with this before? As an aside, I have no brake performance issues stemming from the leak... Brakes work great, I just need to wipe off a little wetness all around the master every day.
Thanks
Steve
Front master re-rebuild questions
- Steve81GL1100
Steve
1996 BMW R1100R
1996 BMW R1100R
Re: Front master re-rebuild questions
I doubt the DOT 5 caused the leak. The wing in my avatar was done in 2006 with DOT 5 and it is as dry as the day I finished. I also had DOT 5 in my race bikes for years and had no issues with seals.
Don't blame the fluid on the seals leaking.
- 9 Replies
- 209 Views
Last post by alwing17
- 4 Replies
- 211 Views
Last post by SnoBrdr
- 6 Replies
- 173 Views
Last post by Whiskerfish
- 0 Replies
- 299 Views
Last post by mtwinger
