engine vin numbers
- gdonlo04
engine vin numbers
i have two engines w/o a frame. how do i ID the year of the engine so i can match the correct carburetor?
ex. GL 1 E 4008175
ex. GL 1 E 4008175
Re: engine vin numbers
I believe they’re all Gl 1E, the 4 indicates fourth year of production, so it’s a 78. I think 77 carbs had two varieties. One was a 764a version of the 77 carbs, but most had 769 carbs.
77 only had 764A carbs.
Durn! 9 looked like a four to me https://www.ngwclub.com/forum/viewtopic ... 14#p453014
The 78 did use two sets, 769A and 771A
- andorragl
I often see questions about serial, engine and carburetors numbers , here is a complete list https://www.ngwclub.com/forum/viewtopic ... 03#p699603
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
78's had two versions of carbs... the first half of the production had the 78 carbs and the second half was the 79 carbs. I believe the 79's engine #'s and VIN's start GL 1 E 41.....
- gdonlo04
thanks for the details. really appreciate the response.
based upon the fact hat Honda used two different carbs on the 78's, either set should work... there was another thread where someone had a 79 with a mixed set (part 78/part 79) that is not a good idea. Basically, Honda de-tuned out the "varoom" factor and made the bikes have better emissions and better touring MPG from 75 until 79. However, as previously mentioned every year had different cam timing etc. so having year specific carbs will always work best
There were early and late model carbs for 78. The new epa rules went into effect 1 January 78 and anything built after that required the newer leaner carbs. So the 78 models built before 31 December of 77 came out with 769A carbs and the bikes built after the first of the year came out with the 771A and those are the same as the 1979 models. The Primary Air Jet was bumped from a 120 to a 140 and the slow air jet was bumped from a 120 to a 130.
yes, mine, built in 4/78 has 771a carbs.... wow that means I could REALLY "varoom" it up with a set of 769a carbs... imagine the power!
- 192 Views
Last post by Kentheshoe
- 65 Replies
- 2361 Views
Last post by gltriker
- 4 Replies
- 273 Views
Last post by rcmatt007
- 230 Views
Last post by Whiskerfish
- 428 Views
Last post by Gowing
