No running lights, gauge lights
Hi, 78 GL1000, I need some help tracking down an electrical problem. I don't have running lights, or any lighting on any of the gauges.
Here's what does work:
Oil and neutral light
All gauges operate normally except for the lights
Turn signals
Brake lights
Parking lights when ignition switch is in park
Headlight
Horn
I pulled the 4 pin plug in the bucket and tested for 12 volts with the ignition switch on, and I got 12 volts from the gray and pink wires, but not the brown/white wire. I tested the 5 amp fuse connection that says meter lamp with the ignition switch on, and read 12 volts.
I don't know where to go from here, so any advice will be appreciated.
Thanks!
Ed
Oh, here's a schematic:
Turn signals
Brake lights
Headlight
Horn
Thanks!
Ed
There is nothing noble in being superior to your fellow human beings. Real nobility is in being superior to your former self.
~Hemingway
1978 GL1000
1987 Shadow VT700
~Hemingway
1978 GL1000
1987 Shadow VT700
Re: No running lights, gauge lights
the first thing always to check is your ground connections. Sorry, but I cannot see the schematic well enough to know what brown/white is for. Then, recheck all connections (and clean). Also, did this bike have a vetter fairing and did the PO use those blue clamp on wire connectors... they often slice wires in half over time
I think the brown/white wire is the power for the gauge lights. I just replaced the harness and went through all the connections so I know those are clean. This bike did not have a fairing.
Thanks!
Thanks!
~Hemingway
1978 GL1000
1987 Shadow VT700
~Hemingway
1978 GL1000
1987 Shadow VT700
I just looked at a better diagram. Yes it is the power line. it runs of the ignition switch so I would check there next. you could simply have a wore ut switch. I do not know if you clean the inner contacts
Thanks I did replace the bottom plug portion of the ignition switch and I checked it for continuity according to the manual before i installed it. There is another brown/white wire from the junction box that I think feeds the turn signal switch sub harness. I pulled the sub harness plug and stuck a probe into the junction box connector where it accepts the brown/white wire and I did not show 12 volts there with the ignition switch on. If i stick one probe in there and ground the other, and the ignition is on, it should read 12 volts, right?
~Hemingway
1978 GL1000
1987 Shadow VT700
~Hemingway
1978 GL1000
1987 Shadow VT700
yes.... this is why we all hate wiring gremlins.... but you just need to keep checking
Solved!
It was the fuse, classic case of looking good but in fact the metal cap on one end was loose. Something I've read about on this forum time and time again. Feel kind of stupid for over-complicating
Thanks for the quick responses!
~Hemingway
1978 GL1000
1987 Shadow VT700
~Hemingway
1978 GL1000
1987 Shadow VT700
I have often replaced things I did not... I hate wiring gremlins
As I read through this I kept thinking "Its probably a bad fuse that looks OK"...
Good to hear you figured it out. Now replace all the other fuses so you don't have problems with them later. The "classic" bad fuse that looks good is usually caused by years of vibration (everything is always vibrating) causing the link to fracture next to where it is welded to the inside of the cap.
I will do that. It's funny - now that I've somewhat learned to use a multi-meter and read a schematic, at any whiff of an electrical problem I immediately start pulling connections and testing wires instead of addressing the easy stuff first. I swear I've read about bad fuses that look good - on this very forum - at least 20 times.
~Hemingway
1978 GL1000
1987 Shadow VT700
~Hemingway
1978 GL1000
1987 Shadow VT700
On our first day of Electronics in high school our teacher said "Always look for the simplest thing that could go wrong first. You don't know how many times every year people pay $5 for the TV repairman to come and plug in their TV."
And if $5 for a TV repair call doesn't date me.......
whenever I check fuses I check both ends to see if there is power... I have done the same thing you did in the past
- n5zhu
I have better luck with a good test light it loads the point you are testing.I have had a VOM show voltage but would open up with anything over a milleamp and send me down the bunny trail. That and its quicker the light is on now a VOM take a bit to show its reading. 73 Patrick
In the sticks So. of Heneryetta OK
1992 Suzuti VX800 Gone Traded for 2nd 78 GL1000
1978 GL1000 X2 1 Up and Runing 1 to go in the shop for work
- 4 Replies
- 146 Views
Last post by Whiskerfish
- 4 Replies
- 211 Views
Last post by CYBORG
- 3 Replies
- 195 Views
- 10 Replies
- 337 Views
Last post by crazyjackcsa
- 1 Replies
- 286 Views
Last post by Casper
